N2STY
Distinguished Member
It made sense to me but then I am dyslexic I to use the demist button when my window is misted up ?I'm sure that made sense in your head but for the rest of the world..........![]()
I find the opposite. Hitting the demister turns on the AC to dry the air and the airflow onto the screen and turns up the fan speed but without increasing the Heat setting. I, therefore, hit the demist and turn up the heat to full and hey presto clear screen in less than you would expect. I do wonder why though that the Demister overrides the Recirculate since My old Renault would turn "Recirculate" ON when Demist selected and would therefore progressively dry the air as it recirculates through the AC and warms the car very quickly.I always use the front Demi’s tee button if the screen fogs. The interesting thing is that it turns on the air on and the blower at full power. BUT you can turn the blower down to minimum so is a useful way to have heater and air on on at the same time. I haven’t managed to find any other way.
I presume these dehumidifier bags are the ones you reactivate by drying in the oven?I now have 3 x 1kg and two smaller car dehumidifier bags in the car and have cleaned the interior and exterior of all the windows with Rain-X window cleaner and have virtually no misting up. I don't have to use the demister as I used to on rainy days, I just set both the heat and fan to 3 blobs to keep it clear if it's a bit cold.
By my reckoning, please correct me if I'm wrong.I presume these dehumidifier bags are the ones you reactivate by drying in the oven?
I wonder how much more kWh that process adds to your energy bill at high daytime rates than the small amount of electricity to operate the AC in the car from the electricity you put there at the cheaper off-peak rate? Not to mention the fuss an bother!
No need for all this stuff if the hvac system is used correctly. EVs are no different to ice vehicles when it comes down to heating and ventilation.I now have 3 x 1kg and two smaller car dehumidifier bags in the car and have cleaned the interior and exterior of all the windows with Rain-X window cleaner and have virtually no misting up. I don't have to use the demister as I used to on rainy days, I just set both the heat and fan to 3 blobs to keep it clear if it's a bit cold.
Not the same. A BEV uses battery power to generate heat which impacts range. An ICE uses some of that wasted 60% to 70% of power to heat the cabin with no impact on range.No need for all this stuff if the hvac system is used correctly. EVs are no different to ice vehicles when it comes down to heating and ventilation.
The MGs AC system is using 4.5KW?? That's like triple the amount my heat pump uses (1.63KW) when its on 100% modulation (i.e never). Seems like a hella inefficient system or car AC systems are weird and out of my understanding. Would love to know more.By my reckoning, please correct me if I'm wrong.
Microwave. 600W for 6 minutes x 8 (I usually do the 1kg ones twice).
48 minutes at 600W = 480Wh (0.48kWh)
HVAC on demist is around 4-5kW lets say 4.5kW
3 minutes at 4.5kW = 225Wh (0.225kWh)
The bags last a month minimum before they need recharging and I use the car every day.
Using the HVAC.
31 (days) x 0.225kWh = 7kWh
So demister bags = 0.5kWh/month
HVAC = 7kWh/month
Even if it doesn't mist up every day, say only half the time, it's still 3.5kWh a month using the demister.
That's when it's on full heat and full fan.The MGs AC system is using 4.5KW?? That's like triple the amount my heat pump uses (1.63KW) when its on 100% modulation (i.e never). Seems like a hella inefficient system or car AC systems are weird and out of my understanding. Would love to know more.
I’ll have a kipper tie while yow is doin it.We eyt it cowd, straight ahtah t'tin, here up north.
Same as wi do wi beynz.
Does your tongue reach the bottom of the tin?We eyt it cowd, straight ahtah t'tin, here up north.
Ahh, full heat. That explains it. thanks KithmoThat's when it's on full heat and full fan.
Mine normally draws about a tenth of that on my usual settings of 3 blobs fan and 3-4 blobs heat.
