DON
Do you need a top spec Trophy IConnect for the voice control commands to work, I test drove the Trophy on Sat and was told need to pair phone to use voice control, can someone clarify this cheers.
You press the button on the steering wheel that you previously used for talking to your phone, then say the command, e.g. 'open sunroof'. I think this only works on Trophy Connect, not on the other two models (SE & Trophy).On existing models you need AppleCarplay or Android Auto to do voice commands, however the new range appear to have (I have not tested on a new model, but my reading says this is the case) in-built voice control initiated by “Hello MG” voice command. This will let you control vehicle functions like “Hello MG open the sunroof”.
Now I'm confused can any dealer on here help please, the button is on the wheel can you use voice control on the Trophy LR .You press the button on the steering wheel that you previously used for talking to your phone, then say the command, e.g. 'open sunroof'. I think this only works on Trophy Connect, not on the other two models (SE & Trophy).
SE and standard Trophy model has limited voice command control from the button on the steering wheel.Now I'm confused can any dealer on here help please, the button is on the wheel can you use voice control on the Trophy LR .
Thanks for the clarification - much appreciated. Brochure does not make it clear as to exactly what the £500 extra cost gives you.SE and standard Trophy model has limited voice command control from the button on the steering wheel.
It will allow you to request a call from your phone, BUT if you want to control the sun roof and climate control etc via the button on the steering wheel, you will need the full spec Trophy IConnect model at an extra £500.
I criticised this point on the forum a few days ago.Thanks for the clarification - much appreciated. Brochure does not make it clear as to exactly what the £500 extra cost gives you.
To be fair, the IConnect does offer more functions than opening the sun roof etc for the £500.Thanks don't think I'm laying out a extra £500 to open sun roof etc
I went for the Trophy non-connect as I didn't think the connect stuff was worth the £500 extraTo be fair, the IConnect does offer more functions than opening the sun roof etc for the £500.
But if you are not going to use ALL of the features, then put the £500 to a nice paint finish.
Metallic paint is around the same price.
good choice I thinkMany thanks Trophy it is
Standard Trophy ( not i.connect ) for me also, finished in Battersea Blue in March 2022.Many thanks Trophy it is
