What dose your HS read at full charge?
  • Thread starter Thread starter Deleted member 3150
  • Start date Start date
  • Tags Tags
    mg hs
D
Deleted member 3150
Guest
I only ever see 100% 32 miles after a full charge unlike the ZS which varied depending on GOM interpretation of history.
100% = 52 Km (32 miles)
it cant read any higher i think,.. its a set value
When the car / battery is brand new, this is completely normal.
If it is anything like the VW PHEV that I owned for over four years, you will see after about 12 months that predicted figure will start to fluctuate slightly after a full charge.
Dependant on weather conditions etc, you will see it start to produce a slightly smaller range on the GOM after a full charge.
This was a common feature that other owners had also witnessed as the pack ages slightly.
First year from brand new, it report the max 31 - 30 miles of predicted range on the GOM.
In the second year it started to report slightly less after the same full charge of around 30 - 29 miles.
Third year about 29 - 28 miles.
These are ALL figures reported in the summer time.
I kept a log of this actually happening, it happened almost at the same point every year !.
The winter reported figures where slightly less of course !.
Lithium Ion packs tend to degrade more quickly in the first 12 months, then the subsequent following months.
The manufactures known this and under report the spec slightly to accommodate the fact.
You COULD keep a record of your ACTUAL mileage covered ( not the predicted range ) and check any decline in range this way.
But to be honest, I would not even bother !.
If the MG PHEV is in any way related to the VW set up ( and there is clear evidence that the VAG parts bin has been heavier raided for the ZS EV ) then I would expect the MG PHEV to react in the same manner, given time.
Just to say, this lower reported range can be a little disconcerting when / if you come to witness it for the first time !.
But it had become an accepted fact with VW GTE owners.
The theory was this in the end :-
“Just charge, drive and enjoy the car”.
Life is too short to be worrying what the GOM reports you SHOULD receive in range.
It is called a GOM for a very good reason.
Remember the figure is just a prediction and not an actual true fact.
It’s guess ( although sometimes fairly actuator ) is purely based on a LOT of fir rent factors, like weather, driving style and so on and so forth !.
It’s much less important in a PHEV because you have a HUGE back up supply of fuel being carried around in the fuel tank.
Use the electric energy to suit the conditions of the trip.
If the journey is short and of lower speeds, use electric ALL of the time.
If the trip is of a longer nature, choose how and when you consume your EV range.
For longer stretches of the journey at higher speeds, then pure electric mode will eat the energy real fast !.
Save the electric range for slower sections and for town work etc.
Does the MG PHEV have a “Hybrid Auto” function ?.
If so, let that judge what it needs on higher speed sections of the trip.
I found the VW PHEV extremely economical and reported anything from 90 -110 MPG.
By the ZS EV beats it hands down for economy.
Enjoy ?!
how long has HS Phev been out ? Has anyone reported electric range changing ? I have a feeling 100% SoC is fixed to 32 miles or equivalent. That means it will never show any degradation and no worries about warranty claims unless someone creates OBD2 BMS reporting tool
MG web site mentions 43 miles in urban driving situations so I would hope it is more intelligent than that
Driving Range EV Only: WLTP Combined Cycle (miles)3232
Driving Range EV Only: City (miles)43
Very similar to my 6 year old Mitsubishi PHEV.....the only reason I keep that is for its 4 wheel drive and its low value. To be honest I think PHEV's are pretty useless for long runs. That's why I bought my MG ZS EV......and hopefully I will be upgrading that for a long range one.....soon.
I have driven it 40 miles and still had 8ish miles left but that’s not the point. GoM is fixed to 32 miles and drops on % irrespective of how many miles you drive.
Indeed - we occasionally drive across a Europe and I wasn’t comfortable with charging across Europe where I don’t always have time or understand the language. That’s why I picked up Outlander last year and when it was written off, picked up HS.
A few years ago my son had a Volvo Diesel PHEV ( can't remember the model ..but it was quite rare) and he often got 60/70 MPG on a longish run.
Modern PHEV's are mostly petrol and its a fact that Diesels do more MPG than petrols. And of course in any PHEV you are lugging a big heavy battery about.
They have their place of course, shortish commuter runs, shopping etc....Great for that, and a 50 mile range is very good, twice as much as my Mitsubishi.
Don’t forget the company car driver who gets good bik relief. And the fleet owner that gets a low cost vehicle able to cover high mileages with fantastic TCO. You dont buy a pHEV to go to the shops. You buy it to able to do your local journeys on ev and then jump in it and do long journeys without interruption or watching the range and hoping the charger is working and available where you need it. PHEV will eventually die out but it’s up the government to give us an infrastructure that allows EVs to be used. There development and charging speeds are outstripping the infrastructure which must catch up.
So HS after a full charge overnight and 14 miles of usage so far is showing 74% and 26 miles
Are you carrying the car??
Done for today
0 miles - 100% - GoM 32 miles
25 miles - 47%. - GoM 14 miles
TBH having driven Leaf and then Outlander one getting into habit of trying to get as many miles as possible. Reckon HS would managed 50+ if it had eco mode.
