Wheel alignment 2025 Hs phev
PDaddy
UK
HS PHEV
Has anybody had wheel alignment carried out on 2025mghs phev.
During the recovery process, the tracking seems to have been knocked out and needs adjusting. A bit nervous as this is a new model, the alignment garage who use hunter equipment say they have alignment data for Hs 2019 onwards, which is the previous model, not sure of the data is the same for the current 2025 model ?
Is the new model just a cosmetic face-lift? If so probably the same, but if the new model is based on a new monocoque, very unlikely to be the same. If the garage's Hunter subscription is not up-to-date or the latest Hunter data (from 21st May 2025, according to Google) doesn't contain the new HS info, then the alignment garage would need to manually input the necessary parameters using data from MG.
