pollenface
- Jan 10, 2023
- Location
- Perth, Australia
- ZS EV
Best done on a cold day without gloves. Seriously, i hurt my fingers taking mine off, they are damn tight
That's a good point, I didn't know you could get long reach caps. The plastic wheel trim gets in the way. I felt rather emasculated when I struggled to get a cap off and put some air into a tyre, especially as I dropped the cap inside the trim where I couldn't get at it ?? and there's no way I'm attempting getting the plastic wheel trim off without breaking it ? Not a great design imho.Getting them short valve caps off can take ages !.
What can make lift a little easier, is to fit the longer reach caps.
At least you can get your fingers around them.
Tyre shops have longer tyre valves that would be perfect to correct this issue and are cheap as chips.That's a good point, I didn't know you could get long reach caps. The plastic wheel trim gets in the way. I felt rather emasculated when I struggled to get a cap off and put some air into a tyre, especially as I dropped the cap inside the trim where I couldn't get at it ?? and there's no way I'm attempting getting the plastic wheel trim off without breaking it ? Not a great design imho.
Sooo no fix then. It's not really the dust caps that are the issue, but attaching and un-attaching the inflater without losing more air than you were originally down. It's a ridiculous design flaw tbh. The only sensible answer to this is to be able to remove the plastic hubcap, but the only advice I've seen about this has been pretty impractical. I'm going to swing by an MG garage, and hopefully discover a simple knack for doing this ?If there isn't, I nay well have the hubcaps removed and just leave the alloy wheels exposed.Tyre shops have longer tyre valves that would be perfect to correct this issue and are cheap as chips.
However unfortunately this simple fix is not possible, because the tyre valves also incorporates the TPMS sensors inside the rim of the road wheel.
The extended valve caps are a simple cheap fix that makes things a little bit easier.
You can purchase metal / brass extenders, but these are affected by bad weather conditions and can become seized onto the original tyre valve stem.
Yeah, I've been told the same thing - not so important for me as I'm in the UK ?Hi has anyone thought what the hub caps / wheel trims are fitted for? My thought is greater air flow into the wheel brake area. I am in Australia so cooling is important. Any thoughts?
That's the most useful solution I've seen. Thanks for sharing ?I have never found getting the dust caps off problematic. Screwing an inflator on though was difficult so I got one of those extender clip on things. This is it which solved the problem.
Hands DIY Locking Tire Chuck,... Amazon product ASIN B08RYX5C53
Ah...so you removed the hubcaps? Are you able to send a picture? How did you get them off?Off and looking great.
I didn’t, i asked garage to do it with my first service . They're in the garage now until I change the car.Ah...so you removed the hubcaps? Are you able to send a picture? How did you get them off?
I have this, and longer dust caps with better grips. Now it’s very easy to put air in the tyres. If anyone is experiencing difficulty getting at the valves, check that the wheel covers are in the correct position. There is one ‘aperture’ that is flat at the outer edge. The others are sloped.I have never found getting the dust caps off problematic. Screwing an inflator on though was difficult so I got one of those extender clip on things. This is it which solved the problem.
Correct, I posted on this forum about this last year.Apparently (read somewhere on the forum) the covers go on a certain way. one of the openings is flatter and this opening should be where the tyre valve is? I have not checked but I have read this somewhere on this forum.
