Wheel rim width, PCD and Offset?
Flatcoat
Huddersfield
Not an MG
The wheels on the HS look to me a bit ‘lost’ in the arches. Does anyone have the wheel technical info as above? Just pondering if I do get an HS how much aftermarket wheels will cost.
The HS PHEV standard wheels are 18x7.5" ET41, with 235/50VR18 tyres.
A recommended 19" fitment would be 19x8" ET40, with 235/45VR19 tyres.
They have a 66.6mm centre bore, on 5x112 PCD, so there are a variety of Audi/Mercedes/aftermarket wheels which should fit.
Take note of the offset though, as anything beyond ET35 - ET45 are likely to affect the geometry a bit (and possibly catch on the arch liners)
If you want to look like a gangster, then 20x9" ET35, with 265/35R20 would look epic. :cool:
Thank you for the spec Miles, 20" works well on the HS ?
