BillyWhizz
- Feb 24, 2021
- Location
- Trimdon village Durham
- MG5
Would this fit the mk 2 ZS EV ?
There is a 5% marginal difference in the size, but the Gen 1 space saver wheel / tyre will do the job for the Gen 2 face lift.Would this fit the mk 2 ZS EV ?
Hi ,There is a 5% marginal difference in the size, but the Gen 1 space saver wheel / tyre will do the job for the Gen 2 face lift.
I switched mine over on collection day.
Miles has confirmed it’s suitability a while back.
The wheel stud pitch on the wheel / hub is different for the ZS petrol version.Hi ,
How can you tell the difference from a petrol Zs spare wheel, to an EV one.
Do the tyre sizes do it or is there a number on the wheel.
If you know I would be grateful.
Thanks very much for detailed response. It is much appreciated. Are you aware of any markings or numbers on your correct wheel. Miles says the PCD is different but I am now wondering if I have the right wheel or not, as I seem to recall it came from my Petrol automatic Zs but possibly the dealer who supplied my Mk1 Ev swapped it.The wheel stud pitch on the wheel / hub is different for the ZS petrol version.
Bit of back ground story if you are interested ?.
When the ZS EV ( Gen 1 ) was first released, MG first incorrectly marketed the space saver wheel kit from the ZS ICE model as a suitable fitment, the kit was about £129.00 at that time.
One of the early ZS EV adopters purchased one of the kits and decide to try the wheel on his car.
Good job he did, because It would not fit the stud pitch of the wheel hub, so he returned it to the dealer.
After some further investigation, that space saver kit was with drawn from sale for the ZS EV and another part number was quickly supplied.
This worked out just fine !.
It turns out, that the ZS EV has the wheel bearing hub set up from the previous MG HS model.
I can only assume that it has larger stronger bearings, due to the extra weight of the EV is carrying over the ICE model.
The MG HS has a different wheel bolt pitch over that of the ZS ICE models.
So, quick answer :- NO - The space saver wheel from a ZS ICE will not fit a ZS EV.
As demand increased for the correct space saver wheel kits, the price shot up quickly from the original £129.00 to around £250.00 !.
I managed to grab one at the original price, I switched it over from our Gen 1 to our Gen 2 on collection day.
PS. - The ZS EV does have the same wheel bolt / hub pitches as a VW Golf ( and a few other models ) I believe.
But if used, you we need the VW wheel bolts to suit the wheel, as the contact angle machined on the wheel is slightly different from the MG wheel bolts.
The thread pitch etc is the same by all accounts.
Hope this helps answer your question .
You can see the MG part number on this photo, the price has now increased to £277.00.Thanks very much for detailed response. It is much appreciated. Are you aware of any markings or numbers on your correct wheel. Miles says the PCD is different but I am now wondering if I have the right wheel or not, as I seem to recall it came from my Petrol automatic Zs but possibly the dealer who supplied my Mk1 Ev swapped it.
Thanks so much for all your helpful info. Is the part no stamped on the wheel anywhere. Also are the tyre sizes different. If so do you know the size fitted to the correct wheel.You can see the MG part number on this photo, the price has now increased to £277.00.
If your current wheel is from a ICE model, it will not fit the hubs on the ZS EV - Sorry.
It clearly shows which models this part number fits.
MG HS / GS / & ZS EV ( no mention of the ICE model ).
I believe they are a bit of a struggle to remove alright.The reason I just haven’t tried it on the hub is that I am not sure how to remove the wheel cover on my Trophy. Didn’t seem to want to budge and I do not want to break it.
Here you go !.Thanks so much for all your helpful info. Is the part no stamped on the wheel anywhere. Also are the tyre sizes different. If so do you know the size fitted to the correct wheel.
Sorry to be a nuisance.
Here you go !.
There is a series of numbers stamped into the face side of the space saver.
Hard to get a good angle on them, so I have tried my best to take a few photos.
The tyre size is shown also .
You are very welcome, glad I could help !.You are an absolute star. My pictures show the same codes. So my dealer must have supplied me with the right wheel for my Mk1. The numbers match yours.
I really am grateful to you
