terrybailey
Any one have a recommendation for windscreen washer Liquid?
Water for summer? The user manual did have something about it but I cannot rememberAny one have a recommendation for windscreen washer Liquid?
Just don't use washing up liquid or any similar detergent. It'll dry out the paint giving it a dulled appearance.Another for prestone but I'll use whatever is to hand as long as it cleans the glass.
Or 80s even. It explained why my Metro's roof of '87 was a dull red.That 70s look.
The cheap stuff will often not include a biocide so you can get biological growth in the tank that blocks the suction strainer on the pump and this invariably leads to the pump failing. It's a bigger issue in the Summer because of higher ambient temperature and lower throughput but it can happen at any time.Totally agree should not use washing up liquid etc. etc., but what is wrong with cheap washer fluid. I have used the stuff from supermarkets for years with no bother.
You could always put a silver coil in the reservoir to kill any bacteriaThe cheap stuff will often not include a biocide so you can get biological growth in the tank that blocks the suction strainer on the pump and this invariably leads to the pump failing. It's a bigger issue in the Summer because of higher ambient temperature and lower throughput but it can happen at any time.
Had this happen on my other car and I had to remove the tank to flush it out as well as replace the pump.
This is what was in the tank:
YepAldi £2.99 for five litres. Been using it for years never had any problems. All those fancy makes just a rip off same ingredients
Does it say on the de-icer about avoiding paintwork? I know it will be diluted but I would rather increase the concentration of the wash.Yep
I’ve always used Asda screen wash
50/50 concentration in summer/winter in my old ice cars
Let’s see how it holds up in the winter in an ev
I did see on a EV forum or YouTube video when I was doing my research into EV’s
that screen wash may freeze easier in an ev as it doesn’t have the heat from an ice engine to heat it up and thaw it out
BUT it said to add some de-icer in with the screen wash it would help to stop it freezing
It didn’t say how much to add or how well it worked maybe worth a try who knows
Cheers
I know years ago it did but must admit I’ve never really looked these daysDoes it say on the de-icer about avoiding paintwork? I know it will be diluted but I would rather increase the concentration of the wash.
