ZS gen 2 mudflaps - these are mine
Neilat226
Leicestershire
ZS EV
Easy to install, close fit to bodywork, look great I think.
The screws for the rears are too close to the tyres to get a screwdriver in, so I used a small ratchet with a philips bit in a small socket. The wheel arch material is very soft so the screws bite in with a bit of pressure in the right direction as you turn the rachet.
Yes I got some of these for mine and they fit really well , look factory fitted and hopefully keep a bit of the road spray of the sides
Looks good,I have the EV Trophy,do you know if I need to drill any holes to fit them,?
the ones I have use the existing holes ,plus a couple of new fixing points but you can use the fixings that come with them to self tap through the plastic , you need an angled screwdriver for the rear or take the wheel off
