Edit: Originally, I thought I had an issue with my Zappi not being able to charge the car, but after testing other AC charging points (cutting out after fifteen minutes or less) and contacting the dealer, I eventually found out it was an issue with the car, namely the charge control unit, which needed replacing. After a new CCU was fitted, the car now charges normally at home on the Zappi (AC charging), though a separate software update was needed to limit the car to 80% when doing such a charge on my SE Long Range. Without that software update, the car was ignoring the 80% limit and charging up to 100%.
For those members who charge their MG4s with a Zappi, has this ever happened to you? The first time it happened was on Sunday. I’d set the car to charge to 80% from something like 45% and let it do its thing. Around the time I expected it to have finished I checked the Zappi app and found it had finished earlier than expected. It had actually stopped charging at 74%. I thought that was odd and then started the Zappi again to finish the charge to 80%, but again it stopped at 76%. Okay, this is not normal. A third attempt got the car charging and balancing to 80%.
I plugged it in this evening to charge the car from 67% to 80% and the Zappi stopped at 78%. The second attempt got it charging and balancing to 80%. I’ve updated the Zappi firmware, just in case that’s the issue, but I’m perplexed as to what could be the cause of this. Any ideas guys? Could it be the car, or is there something I’m not doing correctly? Any help is appreciated. I haven’t had any problems in the last seven months of charging until last Sunday.
