12V Battery Charge low may be limited start vehicle (AMENDED VOLTAGE READINGS)
Tom Hartley
Grimsby
12V BATTERY CHARGE LOW MAY BE LIMITED. PLEASE START VEHICLE.
We have owned our MGZSEV Exclusive from new, it will be 6 in September.
During May/June 2025 the above dashboard warning appeared and after seeking advice from the EV community I replaced the 12V battery (I retained the original....too long a story but there was nothing wrong with it ).
Recently the above warning has reappeared, as too when I have refitted and tried out the old one).
Both batteries mentioned have been charged with a Blink recommended 6A battery charger and checked on and off the EV with an amp meter.
The new battery after a run, engine off, car locked read 12.74, when disconnected, left to stand it read 16.47 / 6 .... differs slightly during various repeat tests.
Those tests have been carried out during different weather temperatures, the last being today when it was unbelievably a sunny 11 degrees outside.
I also left it disconnected as allegedly the EV can then lose any ghost glitches.
Today after a 10 mile round journey. I alighted from the EV, locked it, opened the boot to unload shopping for a few minutes and then closed the boot, the warning appeared.
I previously removed the boot light bulb to eliminate any potential battery drain source
The EV has its full MG dealer service history, the last being September 2025..
I have not yet booked the EV in for an investigation as in the area the "dealers" seemingly want it for the day to examine any warranty work and then a revisit for any potential fix should something be identified. I am hoping to avoid wasted trips.
Has anyone else experienced the warning under the circumstances outlined, if so has a remedy been found?
Apologies for the long story.
Tom, I remember your story about needing a new battery about a year ago. Our car is an early 2020 so is now over 6 years old. Recently I noticed the sometimes the car would not "start" but acted like I had not put my foot on the brake. Also I noticed that the 12V battery was low, showing under 12V when the car was not running. Also I started getting the "12V warning" that you had.. I replaced the 12V battery and all is fine again.
I do not know what you mean about the battery reading 16.47V? I think that is impossible from a 12V battery. If fully charged they should read about 13V or 13.5 V with no load. If it is really reading 16V there must be something wrong with it.
Where did you read the ~16V ?? Was that indicated on the vehicle or an a separate voltmeter?
(You mention using an amp meter. Not sure if you were measuring charge current or actually meant a voltmeter/multimeter?)
If using an external voltmeter, where did you take the measurements across??
Is your meter reading correctly?
I have seen odd voltage readings where there is poor earthing. On an ICE vehicle, this tends to prevent cranking. On an EV, it may not show up so obviously. Just results in there being a few volts loss, enough to cause problems/warnings, on the car systems. And an apparent excess voltage increase when charging.
Our ZS EV had the same message come up when we were in town shopping. We drove to a battery shop and had them test the 12 volt battery. The battery passed the load test.
Still I got them to put in a new battery anyway.
No more messages from the car about the 12 volt battery being low.
In your situation I suggest cleaning the battery terminals and lugs and see if that helps.
Also make sure the earth connection on the car is clean as well.
Our battery had a small hole in one corner at the top, that a rat had chewed into it. That is one reason I did not trust it and had it changed.
good luck
Pete
Tom, I remember your story about needing a new battery about a year ago. Our car is an early 2020 so is now over 6 years old. Recently I noticed the sometimes the car would not "start" but acted like I had not put my foot on the brake. Also I noticed that the 12v battery was low, showing under 12v when the car was not running. Also I started getting the "13v warning" that you had.. I replaced the 12v battery and all is fine again.
I do not know what you mean about the battery reading 16.47v? I think that is impossible from a 12v battery. If fully charged they should read about 13v or 13.5 v with no load. If it is really reading 16v there must be something wrong with it.
Apologies for my mistyped voltmeter readings the information should have read:
The new battery after a run, engine off, car locked read 12.74, when disconnected, left to stand it read 1227 / 6 .... differs slightly during various repeat tests.
I have also retested my now spare old battery and it too shows a drop of .4 to .5 drop when subjected to the same tests.
I have examined visible wiring and terminals were and are clean and leads were secure.
Anyone any ideas / remedy
So what you are saying is that 12.27V with the car "off" is not really low enough to trigger the "Battery too low" alarm signal. I would say it is right on the margin. 12V should trigger it, because a normal battery should sit at about 13V. Maybe your newer battery is not too good either? You could take it to a garage for a load test to see whether it fails that?
Just as an aside.
I suspect that many of the car systems are still running directly after locking. Taking a while for them to all 'go to sleep'.
So the voltage may come back up a little once the loads are removed.
(It is actually possible that having the bonnet open may even keep things running?!)
So what you are saying is that 12.27v with the car "off" is not really low enough to trigger the "Battery too low" alarm signal. I would say it is right on the margin. 12v should trigger it, because a normal battery should sit at about 13v. Maybe your newer battery is not too good either? You could take it to a garage for a load test to see whether it fails that?
Thanks for your suggestion regarding load testing which I have followed.
All good but I am still experiencing the same issue i.e. that dashboard warning and after a short while it changes from reporting the 12v battery may be low .... start motor to ..... immediately start motor.
The voltage seemingly drops .4 on either 12v batteries that I have.
When the car is locked, bonnet open, the warning is triggered after the boot is open for a short time e.g. getting shopping out.
The same occurs when the driver door is opened, left open for a short while and the motor not started but I acknowledge that it will clearly wake up various systems.
I have tested both and if I disconnect the earth lead the battery voltage (on either one I fit) quickly goes back up that .4 loss that's apparently triggering the warning.
I am finding it somewhat puzzling and resorted to carrying the "spare" battery when it's not in use .
PS all visible wiring is intact and terminals are clean with leads quite secure.
Tom, all very interesting. I have a slightly similar issue. My car began not "starting" on the first push of the start button, it would just "hang" so one had to turn it off and begin again. So I bought a new battery from Tayna and the problem disappeared for a while but has now come back again. I think the battery sits at a slightly low voltage when not being charged. I have put a query in to Tayna to see whether they can help.
Ps, I suppose it is possible there is a standing drain on the battery, I have not tried measuring that.
I considered trying to monitor the 12V battery via a Codiac BM2 Battery Assistant monitor Bluetooth 4.0, but just to give you the heads up, it was not compatible with my 2020 Exclusive EV.
I interrogated its incompatibility via the web and AI which comically concluded ...the monitor "would make a good paper weight".
An auto electrician should be able to tell if there is a parasitic drain on the battery.
Or you could buy a cheap DC clamp meter, they have a clamp that goes around the cable you are testing and measure the current flowing in the cable. They will show also if the 12 volt battery is being charged when the High Voltage battery is turned on.
Have you made sure that the battery terminals are clean. There are cheap battery terminal cleaners available that have a small wire brush inside to clean the inside of the battery lead clamps, and another wire brush in the other end that cleans the battery posts.
It is always worth checking the condition of the battery terminals and posts first
Pete
When I get time I can easily measure any drain using my multimeter.
Tayna have suggested I give the battery a good charge with a proper battery charger which I will do. I should have done it before I fitted the new battery but I was short of time then, too.
Hi, regarding a good battery charger I bought a Blinkk RSC806 6amp one from Sutton Auto Factors, £29.99 including postage. At the time it was the cheapest new one I could find, it seems good and has a 7 stage charging process which goes into battery maintenance in left connected. Cheaper used and or refurbished ones were available elsewhere but I opted for one I hoped could be trusted.
Pete
Thanks for your contribution. I had cleaned the terminals and clamps plus, so far used an amp meter.
I am monitoring the situation currently and may well follow your guidance regarding an auto electrician, the one I hope to use is currently on holiday.
