Lovemyev
Distinguished Member
I really do like your own approach in trying to identify the root cause of the energy loss from the factory fitted 12 volt battery1000% agree.
Like @Ian Key I keep mine under the centre console, at least I do now! Having had the (slightly) humiliating experience of calling MG Assistance to a totally flat 12v battery (AA measured it at 4v) and being unable to access the booster I bought two years earlier (and never needed with the previous MG5) and having to admit to the AA Technician that it was in the boot!
(Just as an aside, the technician arrived at my house in rather less than 1 hour after calling the assistance line, so absolutely no complaints there!)
But, on a broader point, @Joningy is yet another MGS5 owner experiencing this 12v battery problem.
Since my recent experiences of needing to use the booster four times, and a full 2-day diagnostic check at my local dealer (which found no fault, of course) I have been making at least one check of the state of the 12v every day and recording the voltage shown by my 12v charger (accepting it's likely to be not "wholly" accurate, so just an indication of changes). The figures reveal that, following a full charge by the 12v charger on December 22, the voltage was given as 12.8. Since then the figure has gradually reduced until yesterday afternoon, December 30, it registered as 12.0. There was one "increase" in the figure, December 28, when it read 12.3 (from 12.1 the previous day) after the HV battery had been on charge overnight.
This morning it read 14.7 (!!). Car was not "on" or even "booting up" so that suggests, I think, that the HV battery was carrying out the "Intelligent Battery Charging", perhaps? No overnight HV charging this time either.
But if it was the Intelligent Battery Charging, why has it not done the same before now???
EDIT, to add: all those battery voltage figures are part of the evidence I intend to pass to my dealer when the car goes for its next diagnostics check, next week.
Maybe when you are not likely to be using the car for a few days, try this.
Disconnect the negative terminal on the 12 volt battery and record the voltages from the battery at a standing state, over a few days.
Is there any significant drop in the voltage now ?.
If so, this would strongly suggest that the battery is incapable of retaining energy and is faulty.
If the battery completely retains its energy, this suggests a parasitic drain by the car.
I just have a feeling that the batteries fitted to the S5 are of not great quality or they just about have enough capacity when the they are at there very best state of charge.
Any amount of drain caused by short trips or long stays of non use and they fall away quickly.
Reducing the size / weight of 12 volt batteries saves money.
EV’s weigh enough as it is due to the traction battery, so any reduction elsewhere is welcomed by the manufacturer.
I can’t help but feel that the factory fitted battery is just about doing its job, but with very little margin for any slight extra drain.
A better quality battery with more storage capacity, that offers a larger margin for discharge, has to be a better option surely ?.
