EssBees
Hi, apologies if I'm posting in the wrong area, it's my 1st time on here. I'm hoping for some advice wrt my 12v battery.
I have a 12 month old ZS SE long range. Monday night I charged to 100% as I was making a 250 mile round trip on Tuesday. On my return home I was running low so started charging to 80%. When I went to disconnect from the charger to take the car out this afternoon the car was completely dead. (I needed to use the little key in the fob to gain entry and release the emergency pull to undo the charging cable). The AA came out and found main battery fully charged to 80% as planned but 12v at 1.75v. Nothing had been left on overnight. When the charging cable was connected we could see the 12v battery taking a charge (much higher rate than charging just with car powered up). When the main battery was not charging ie set the limit to below 80% and no charge was going into the car, the 12v battery had 7 amps coming out. If I disconnected the cable, then the charge lost from the 12v battery whittled down to almost 0.
It seems if I am able to disconnect soon after achieving a full charge I should be OK ( I have my fingers crossed it will get me to work tomorrow morning) but something isn't right. Will this most likely be an issue with the car for MG to look at, my charging cable or my charger? The car is booked in for it's first year service in a couple of weeks but is this something I should raise before? Anyone had anything similar and how was it sorted? Thanks for any info.
