12V power socket - how to protect the battery
dx4100
Uk
MGS5
I have a electric tyre air pump that plugs into the 12V socket. On my ICE car I have to have the engine running so the battery doesn't go flat.
How does it work on these EVs ? If I power on the car will it draw power from the main battery and protect the 12V battery ?
Bit of a noob question but I am a noob :D
The 12V power outlet is only rated to 10A (120 watts) so check that the air pump is less than this.
I use a self contained battery version that has plenty of power to adjust the pressure on all 4 tyres when needed.
The 12v power outlet is only rated to 10A (120 watts) so check that the air pump is less than this.
I use a self contained battery version that has plenty of power to adjust the pressure on all 4tyres when needed.
Thanks for points this out. The inflator is 12 V, 180 W, and 15 A so thats a no go....
The one I bought is on the left. I've found it to be very good, easily adding a few psi to each tyre due to seasonal pressure changes and the otherwise usual TPMS alerts, however it is currently unavailable. A close match is the picture on the right.
I got the Goodyear cordless tyre inflator as I wanted a brand I recognised and that would hopefully meet the UK regulations for charging safety and not a corner cutting Chinese import.
Not sure if it was meant as a joke, but I just had to laugh at the 'corner cutting Chinese import'. 😂
I blew the 12v socket fuse with the pump supplied with my MG5. You have to take the car apart to get to fuse box. Don’t know if S5 has same fuse box location hidden in front of drivers knees, but if does, try not to blow any fuses!
Foot pump requires no electricity.
@Jazzyboy, yep I can vouch for the one I have and posted a picture on #6 of this thread. I had tyres on another car that had pretty much deflated, <10psi. The pump took them both up to 26psi. They're not that fast but it has enough battery capacity to run for 15 mins at a time for each tyre without issue.
Cheers all - I picked up the Ring RTC4000. I need a bleed valve for my ICE 4x4 car as I need to be able to change the pressures quite a lot on different terrain / loads.
