Paul V Smith
Just looking at my home EV charging cost for the whole year of 2022, total £160. 1892kWh @8.5p per kWh, through Octopus.
Peak rateWhat is/was your peak rate? Did you time-shift other usage to use the off-peak rate?
Peak 40.06pWhat is/was your peak rate? Did you time-shift other usage to use the off-peak rate?
As I have solar & batteries, I rarely use the grid, but I would say it would work out cheaper, interesting thought though.Have you done the sums to confirm that your total usage is still cheaper vs the standard cap rate (£0.3396 ... 33.96p)?
