2022 Trophy LR rear lights
Zebedee
York
Are the rear lights LED as no where does it say that as a fact please? I've seen many light clusters that imitate LED lighting very successfully and guessing this is the case with the MG. If they were LED MG would use it as a selling point. Cheers for any factual info.
I believe that the rear lights on the face lift model are LED’s.
Any links? Unless it's mentioned they'll be incandescent.
Here you go !.
LED’s front and back on the face lift, covered in the first two minutes of the video from Miles Roberts.
'you’ll see the newly-designed LED tail lamps
that give the car a bold, distinctive expression.'
Cheers, wonder why it's not on the spec or a selling point? Spec says LED centre brake light.
Page 271 of the owners manual says LED.
Thanks. LEDs are the way forward and hopefully covered by warranty but unfortunately not easily fixed like a filament bulb.
I speak from experience having had an issue before.
SWMBO had a 2006 Prius with LED brake lights, when the LED part failed she had to replace the whole light cluster £160 just for the unit, a bit more expensive than a bulb. ? The annoying thing was the LED circuit could easily be removed from the cluster and repaired or replaced, probably a £2 or £3 circuit board.
