21 plate ZS EV -over 200 true miles on a charge? And the next service quote nearly £500 WHAT?!
Laurence Brown
Malvern
ZS EV
So this past few weeks we have been getting around 205 miles on a charge, in and around Worcestershire. It's no longer dropping suddenly down towards the 160 mark as it usually did. It just drops mile by mile.
Perfect.
However, it's going into Gloucester MG next week for a it's annual service and MOT, at 45,000 miles.
What would they be quoting £450 - 500 for?
What are they going to do, gold plate the discs?!
Is this a normal service fee please?
Anyone else had their ZS serviced at this age and milage?
Thank you
I had my 69 plate serviced by Swindon MG in February on 30,000 miles for £313.
That included 2 bulbs, pollen filter, brake fluid, washer fluid and MOT. So I'd say that's very steep
I appreciate yours is higher mileage but I'd like to know how they justify that huge difference in price
Perfect.
Thank you
No way! Shop around and also shop around for a service plan (can do it online), see what it comes up with. I'm now on a service plan, 4 years, about £19 p.m. direct debit. And £35 for MOT every year
Perfect.
Thank you
I took my other vehicle in for a 6th Yr service suzuki with only 23k on clock from new got a service bill for £820.00 just oils and AC on Monday! Last two yrs I have serviced it my self! But do need to keep a service history as this vehicle has gone up from new by £10k to £27-£30k !!
If the air-conditioning is being serviced as part of the overall service that still may not be too out of the ball park. Although it is still a bit on the steep side. The air con can add anywhere from £199 to £250 or even more to the service charge dependant on who is doing the service. But to keep your warranty it must be done.
The service charges seem to go up every time. I paid over £400 for the 5th service this year at Waylands Oxford. But don't believe your 200 mile GOM, you'll actually get about 150 miles as you'd expect with about 10% loss of battery at that mileage. The service record will show what the battery measured at the service.
Yes Tim, they do have us over a barrel regarding servicing to keep warranty & breakdown cover. But we would have to pay for that if MG didn't provide that at each service for free.
On a slightly different note, I noticed there's a very interesting video by 'Kate & James' on YT concerning a 6yr old ZS EV that's been used as a taxi for it whole life. It has 238,000 miles on the clock. Interestingly the battery state of health still shows 93%. Apart from some wear to the seats & one or two other minor issues that included a worn engine mounting, the car is pretty fit. Drives ok apparently. A testament to how good these cars are.
Why not look up MG service plan ? Find your local MG garage and get an online quote. Example for my ZS with 55,000 miles on the clock, but I guess it also depends on your location and competition:
That MG plan isn't actually an MG plan. It's from Brown & Gammons backed by MG. But it's probably quite a good one. Limited transferability I suspect like most & with the usual cancellation fees which might include management fees too.
2025 - 2021 = 4 year service
If the 2021 has the same serviceplan as the 2022+, the 4th is more expensive because they flush the coolant system for the batteries and refill it with fresh coolant.
Also, they do a brake fluid change every second year so this is also included in year 4.
To be honest, my take on these 2 things is....They can not charge you for oil change, exhaustpipes, sooty engine cleaning etc, so they have had to make up something to keep the service money coming in.
Changing the coolant on a closed system, if it has no leaks it seems very suspect, they need to change the coolant.
Also, i know brake fluid is hygroscopic and attracts water, but again, changing it every 2 years seems VERY excessive if there is no problems with the brakes.
My tesla has NO requirement to change any of that and i dont believe Tesla uses coolant or brake fluid that is SO much better.
That being said, i understand the garages are suffering now more and more people drive EV's that require a LOT less maintenance and service, but this is kind of silly to do "not needed" stuff.
If they had brake fluid change every 5 years i would think it was ok, but every 2 years is wasteful.
Baylis Gloucester are hopelessly out of kilter with their service pricing. I asked them to quote for my 4th service (low mileage) and they said their system doesn't recognise the low mileage option so came up with a figure of £372.44 for a standard mileage service.
Checked two other places nearby and they came up with much more realistic quotes:
Drive MG North Bristol - £150.94
Cinderford MG - £108.50
As you would guess, I'm booked in with Cinderford.
The reason for the battery coolant change is due to the fact it's an OAT coolant. OAT is less toxic. However, even in a sealed non ice engine environment it require a change at 4yrs. After that OAT coolant starts to become very acidic & unless changed starts to eat the metal components inside the cooling system. It's used as engine coolant in many motorcycles & in that environment it has to be changed every 2 or 3yrs. Choice of coolant type used is dependant on the type of materials used in engines or in this case, the battery coolant system & also local legal requirements (in this case, the EU). It's being less toxic than most other types of coolant is what manufacturers are looking for to please the government environmentalists & further save the planet. It's safer for us & everyone. It's not an expensive coolant either.
It's normal for nearly all car manufacturers to require a brake fluid change at every 2yrs whether it's an EV or an ICE car. My own MG dealer does the sensible thing & actually tests the brake fluid at 2yrs for moisture. If it's above the recommended levels they change the fluid, but if it's ok they let it go another year. I'm lucky to have a great dealer.
Okay, i wonder why other manufactures like Tesla do not recommend this, maybe they make their batterypacks out of something that does not corrode even if the coolant is not changed ?
I have a maintenance plan, i pay monthly, so i fully expect them to change it though, i am paying for it, via the fixed monthly plan, so if they decide NOT to change it, i would want a discount :)
I will see if i can remember to look at the bleed nipples, it should be fairly easy to see if they have been "disturbed" and if not, i will certainly take it up with them :)
The difference maybe cars from the US use different metals but they also surprisingly don't work to the same safety standards as the EU on these type of things. I suspect the cars from the US going into the EU may have OAT in them as a condition of being able to comply with EU rules. But as we are not in the EU we may have one of the many other more toxic coolants which last longer. I can only speculate that might be the case.
Hi Fred, sorry, didnt see this before - That's a great idea. I will search online. Thankyou.
That is what Baylis did to me a year ago, They just gave it the full 50,000 mile service at just over 40,000. I am not even taking it there next month, I'd rather travel further to not feel ripped off.
Tim, with regards to the higher mileage I am getting, much higher now at 50,000 that it was at 30,000. It's on a 21 plate. the 205 mileage is a full overnight charge with my Ohme. The all driving is in the lanes and roads around Malvern and west into Wales or Shropshire. No HVAC AC and on Eco mode with full kers. I am still on the original 12V battery as well. When the outside temperature is above 9 or 10 degrees the mileage seems to be much better. Yesterday was around 19 degrees all day and we ran from Malvern to Ludlow and Clee Hill and back on the B roads. I take my time, I am cautious - if not just boring. We began at 187 miles and returned with 60 left. If I run to Bristol and back on the motorway, around 55 miles, I am screwed to get back again and always have to charge again in Bristol to get back. The difference between A roads speeds, and highways and the back roads around hereis phenominal. We had 103 miles showing for about ten miles on the way back yesterday, hardly used any juice at all in the twisties from Clee Hill through Tenbury.
Love this car!
