TwoOneBee
- Jul 18, 2023
- Solihull
- MG4 (2022-2025)
Has anyone had a problem with the AC thermostat? Recently the internal temperature has been reading far higher than the actual temperature which has resulted in the AC running very cold even when set high.
I’ve attached a picture. The top right temp is showing 28 degrees C when the true temp outside was 12.5 degrees C. Even with the AC set at 25 degrees C it was blowing cold.
Does the internal temp impact the temp of the AC? And is it a trip to the dealer or can it be reset?
Thanks.
Thanks.
