Alarms . key and Tyre
Drumpot
Dublin
Hi,
I have an alarm for tyre pressure of front left. I havent seen this before, can I just pump up the tyre myself and it resets or do I have to goto a dealer ? Where do I find what tyre pressure should be ?
Second alarm is for the key. The car key stopped working once for a few mins but seemed to work again. Its working now but I keep getting an alarm on the app. "Key battery warning". Is this telling me to replace the battery, and if so how do I do that ?
Yes.
Pump it up to the recommended pressure which you will find on your driver's side door pillar.
The alarm will stop.
Pry open your key fob with a small screwdriver.
Identify the battery and replace it.
If you are not confident youtube will help or your local timpson.
The worst case will be your dealer unless they do it F O C.👍
Edit, If the alarm goes off subsequently you might have a slow puncture.
