pmknowles
No, if you have one set of tyres which is gripping better than the other you can induce 'snaking' in the vehicle - check out HonestJohn and othersFront & back is fine. It's mixing on the same axle that's bad.
In the 80s and 90s, I used to put the deeper tread/ new rubber on the front. No tyre fitter told me different.And more grippy at the rear is ok.
If you're driving on an icy road having grippy tyres on the back is fine until you come to a corner. If you turn the wheel and the front wheels lose grip you have no braking effort on the front and rear wheels gripping in a straight line to push you off the road....And more grippy at the rear is ok.
Although I personally would not do it because I have a rubber fetish…
We've been having a similar discussion on 'MG4 tyres' thread and I'm heartened by your experience as it was suggested over there that mixing all seasons on the rear with summer tyres on the front was not a good idea, but is exactly what I'm planning as the Bridgestone Touranza's on the rear are getting very close to the markers after only sub 11000 miles. Apparently they reduce the tread depth on new cars to reduce road noise.After a couple of weeks in all weathers, I can confirm I am still here with my rears on All Season Michelin Cross Climate 2s and the fronts still on the original Chinese summer tyres.
No handling issues, everything is great and rear grip seems better, no signs of slippage (used to spin a bit backing onto my drive with the old tires, none of that with the new ones).
So it may not be recommended to mix types, but I am not having any problems. YMMV.
It is true that it isn't recommended, due to the differing levels of grip in different situations potentially causing an issue.We've been having a similar discussion on 'MG4 tyres' thread and I'm heartened by your experience as it was suggested over there that mixing all seasons on the rear with summer tyres on the front was not a good idea, but is exactly what I'm planning as the Bridgestone Touranza's on the rear are getting very close to the markers after only sub 11000 miles. Apparently they reduce the tread depth on new cars to reduce road noise.
Well, yes of course, that's why winter tyres are recommended for temperatures below 7C, whether the road is dry, wet or has a covering if snow. They make a massive difference in these conditions. This is why in countries such as Germany and Austria, everyone (by law) changed their wheel sets in November to those shod with winter tyres and back again in March.All tyres behave differently in snow, regardless of temperature.
If it's 'not recommended' and you have an accident you might find that you are uninsured. It's not about snow it's about ice too. MG4s are RWD. If you have the rear wheels 'pushing' you into a corner and the front wheels lose grip no amount of extra grip at the rear is going to help you. I live in the North East, we have snow every year and I have a set of winter wheels I put on at the end of October every year. When I had a Saab 9-3 I could get up snowy hills that 4x4s (with normal tyres) couldn't get up. My driving instructor told me (50 years ago) 'no slower than 20 - no faster than 30'It is true that it isn't recommended, due to the differing levels of grip in different situations potentially causing an issue.
However, I've had the mix for months now and never had the slightest issue in any conditions including heavy rain.
It is true that we only get snow every 20 years or so and usually only a dusting then. But the main issue with snow is rear traction from the drive wheels which should be much better. Could it overwhelm the fronts? Possibly, but that's not something I am likely to experience - with the severe hills here driving in snow is basically a no no anyway.
I can't do anything beyond share my own experience and note that it isn't recommended, you need to make your own judgement.
Yes, I did mention that somewhere, but there are a few tyre threads and it's probably floating around in the ether somewhere. At the time of release, Michelin sent me an email announcing the launch, but my local tyre fitter was still advertising CC2.CC2 fans should note that Michelin now make CC3 instead.
I used Black Circles and paid around £650 for all 4 a few months backYes, I did mention that somewhere, but there are a few tyre threads and it's probably floating around in the ether somewhere. At the time of release, Michelin sent me an email announcing the launch, but my local tyre fitter was still advertising CC2.
They still are today. Just for fun, I plugged in the MG4 and it came back with an eye watering price of £202 per corner for CC2, not including a 10% discount for 2 or a 15% discount for 4.
