Am losing initial 'creep' in drive and reverse.
Erisaman
Swansea / Neath
My ZS Ev has covered around 1600 miles but now loses that initial creep factor when about to drive or reverse. We need to gently (very gently) touch the throttle to trigger movement.
I've tried switching off and back on again - makes little difference. The fault is spasmodic, comes and goes.
Any thoughts before I return it to the Dealership?
I assume you've already checked this, but just in case - You've not knocked the 'Auto Hold' on without noticing, have you?
Hah! Kithmo just beat me to it (and with a fuller answer to boot!)
Sounds exactly like you've switched on the Auto Hold button (next to the big Park button)
I'm hoping that is the answer - proof will be tomorrow. I activated the switch and it showed an orange light, activated switch again and it went out - and the car moved (it's inside my garage so not a full test). I'm not sure I've ever seen that switch illuminated before, so tomorrow I will be watching - my wife will be driving whilst I do so :).
Thank you again.
Yeah the Autohold is great for commuting in stop-start traffic but I find it a bit of a nightmare when reversing, as I tend to jump backwards when it’s engaged. So now I turn it off on those rare occasions I do reverse…
