ReintjeWA
- Oct 17, 2024
- Location
- Perth, Western Australia
- MG4
Inside the corner of the windscreen like most people do when the front plate falls offIt's all getting, rather complicated, just to put temporary Rally Plates on ya car.
I'm sure you can shove them somewhere,
satisfactory.![]()
No definitely just to the side and below the front facing camera... (A) - so if you were looking at the car from the front it would be just below and to the left of where the camera is (if fitted!). (B is the radar module in light blue).I thought it was the square area below the number plate that is recessed? That's the obvious place for me and the bit that I try to keep clean.
Then I could charge people for rides - sounds good
I have a MG4 Standard range (have no camera in front) Is the radar located in the same position anyway?I looked through some manuals and the radar module is definitely above the numberplate. And next to the front facing in-bumper camera (circled in green in the second picture). So in @DocMark 's use case mounting the rally plate below the registration plate might still be the preferred option.
I would assume the radar will be in the same location, yes. But this shouldn’t prevent you from installing a light bar.I have a MG4 Standard range (have no camera in front) Is the radar located in the same position anyway?
I am thinking of mounting a led bar above or under the license plate.
