It's basically when the battery cells level off. So the car may say 100% but its one of the cells that is 100%. So if you charge it beyond full for I guess a couple of hours all battery cells will level off to 100%.Another newbie question. I've seen mentions of a balancing charge. What is this, how do I do it and when/how often should I do o it. Many thanks
Hi, it does battery balance on fast chargers as they are AC but not on rapids as DC.Oh and I believe it won't do this on fast chargers, only your home ones. Probably wouldn't want to do it on a public charger anyway as it would probably fine you for staying there too long and it would annoy the hell out of people.
You can choose the length with a tethered too (depending on manufacturer) - and not carry an excessively long cable about with you - and my 10m cable wraps neatly around the unit.With a untethered one you also get to choose the length of cable and don't have to have it hung outside your house
I have the portable one too. The tethered one is simply quicker. Unplug it, put the end cap on, place on ground, and jump in. The untethered one takes much longer, and when it is cold, raining etc not much fun. Just my opinion.Really? I couldn't think of any circumstances where I wanted a tethered one. Why would you want one? I like having the portable cable - and if you change the car to one which uses a different plug then you don't have to have it changed at the wall unit - just get a new cable (and sell the old one for good money!)
My car spends a lot of time plugged in at home (waiting for then trickle charging from surplus solar) so the cable gets quite dirty/wet. It would be a real hassle to have to coil it up, clean it, and put it in the boot every time I go out. I have a separate type 2 cable which I carry with me for public charging. Best of both worlds.Really? I couldn't think of any circumstances where I wanted a tethered one. Why would you want one? I like having the portable cable - and if you change the car to one which uses a different plug then you don't have to have it changed at the wall unit - just get a new cable (and sell the old one for good money!)
