Better alternative to miles/kWh?
marsw2
Purely
MG5
Why not display miles travelled per battery % used (M/%U) rather than M/kWh? Then the remaining range displayed can be a calculation of M/%U x remaing_battery_% (M/%R) ? Much simpler and in my experience, accurate.
Thoughts?
either that, or car displays kWh remaining instead of %. remaining.
I agree having to do a conversion between % and kWh is a pain.
If you use m/% you can't compare between vehicles with different batteries.
Sticking to m/kWh is a more universal unit, and is better for comparisons.
So personally I think the % remaining, should be a minor element on the display and kWh remaining the prominent display.
Thoughts?
Miles/kWh is the current ‘industry standard’ as per @decrep ‘s post above. It’s also easily measured by ‘real time’ sensors (distance, battery voltage/current).
SoC on the other hand is ‘computed’ and doesn’t seem to be straightforward to determine as battery capacity depends on various external factors.
I assume 2 miles per percent, after the GOM has stopped calculating. As long as that figure is higher than the miles home on the sat-nav then I'll be fine.
Thinking about it, we assume a minimum 200 miles per full charge and have not had any less so far.
I err on the safe side, at low SOC, because the range seems to drop faster at the "bottom" of the battery. I get more like 2.5 miles/% overall.
I find the % gauge works fine on the SE because it has a roughly 50kwh battery.
This means you can just half (or double i.e. 200%) to switch between kWh and percentage.
If you've got 40% left on your battery, then that is 20kWh energy.
This calculation will be harder to do in your head on the larger battery editions, though I guess it is roughly 2/3rds (time and a half or 150%) for 65kWh and 3/4s (time and a third or 133%) for 77kWh.
Simples!
Why not just use the GOM?
I don't find it useful generally, except on a long trip, or when returning home with ever decreasing range.
I'm just saying you can work out other things from the information you are directly given, if you are curious.
A deviation from the original point of the thread I know!
However, if you have an SE doesn't doubling the miles/distance figure give you the M/%GOM one anyway?
I’m curious, so what other things are you talking about?
This was originally about efficiency measures/readings.
But you can think about quantities instead - how much energy do I have left in the battery/how much do I need to charge (buy)?
All these things are related, obviously.
Just thought I would share how easy it is to do the multiplication/division when you've got a 50kWh battery.
Thoughts?
This is pretty much what I do, it works fine for the MG but some other makes don't show a percentage at all. I've seen a progress bar with no numbers in one Toyota and you could probably do something similar with it after you got used to it.
Mostly safe but on rare occasions not so good. I charged the car last January just before a run out and even at 100% charge it estimated a mere 185 miles range. As it happened, I wasn't going anything like that far so it wasn't a worry. This is in the far North of Scotland, and at one point on my journey that day the car recorded the outside temperature as -13°C, so it shows how sensitive EVs are to the cold. Mind you, I can't remember it ever getting that cold in Stockport, so you should be OK...
