Trevor
Sent to dealer
Please confirm how long it is expected to take before the battery equalises properly (after 15 Jan BMS update), and if there are any scenarios that can be implemented to facilitate reaching this point quicker.
As you can imagine, I am still suffering with range issues. Although the car was charged up to 142 miles whilst in the garage, I can only charge it to approx 100 miles, but I'm only getting about 45 miles driving range, and not prepared to tolerate this much longer.
I have already done the following:
2x greater than 24 hour charges
5x overnight charges on granny charger
5x daytime charges (avg 6 hrs each) on a 22kW charger
Thankfully I have a charger near work, but as a slightly disabled person, this walk is uncomfortable and inconvenient. Let alone arriving at the charger today to find the front flap was frozen closed and I had to park the car in the sun for a couple of hours before I could return it to the charger.
Furthermore, I cannot fully charge the car during my cheap (4.7p per kWh) rate and am having to pay public charge rates every day. I cannot finance or use an underperforming vehicle and will be requesting a warranty change of battery if this is not fully operational very soon.
--------------------------- Reply from MG --------------------------
We are not going to replace the battery.
As long as the updates have gone in, the car will recover. I appreciate that it has been inconvenient and will continue to be so until fully recovered, but it will recover.
Even though you cannot provide the SNOW case, I have no problem with you typing out a transcript of the case, obviously leaving out the names and details of the technicians involved.
Brief transcript notes of case
Customer complaint low range on the full battery ,battery range 30 miles with message connect slow charger and HV battery w/l on dash , VDS test reset all DTC and recharging battery for 20 hours , road test and reset VDS DTC PIEDE-00cell voltage difference suspect software issue
instructed to carry out BMS reprogram ,once updated allow an overnight slow charge so a equalisation can take place , the range will recover however this could take a month or two depending on how unbalanced the battery is
