Boot handle stuck on Mk2
lusitano
Reading, UK
Hi All,
Wondering if you could assist here, I noticed today when I went to open the boot door, the handle is stuck halfway or takes me a few tries for it to open now, it's like it doesn't spring back into position anymore, I can't see anything obvious.
Apologies for the quality pics it was raining, we got in last night from a long trip so didn't even notice this.
Should I call my local MG dealer to get it repaired or it's something I can do?
Here is a video I took of it. I think you right spring could be the issue but when I look at it I can't see it being broken.
Hello @lusitano,
I had exactly the same problem and just happened across this post. I looked underneath and the spring looked fine. I then sprayed a little 3-In-1 oil (aerosol can not traditional oil can) and it now works fine.
The weather has been quite bad here and the rear door had a lot of road spray and dirt so I am wondering whether this has collected in the hinge area.
Hello @lusitano,
Thanks, I'll check it tomorrow as I WFH, will update if it resolves the issue.
