Brake Accelerator Pedal Plates
JeffMcC75
Belfast
Has anyone tried fitting replacement pedals?
There are some available on ebay, just wondered if anyone had tried fitting them and if they were any good.
Yes i have a set fitted bought from ebay. You have to take the original rubber off the brake pedal before fitting. Good tight fit and looks loads better than the cheap crap from MG.Those are the same ones from the same seller i bought.
Is it difficult to get the original covers off
Hi, I've ordered some. Regarding fitting, do they clip over the current pedal (sfter removing the brake pedal rubber), or do they slide along the metal of the pedal it till it stops? if that makes sense?
They are rubber at the side and fit over the pedals. Accelerator is more difficult to fit, make sure its fitted over the top corners of the pedal.
I've just got my pedals and I found this video to give me an idea what changing them over will involve.
I found the brake pedal tight to fit, but at least you know its not going to come off. Just takes perserverance
The accelerator fit is slightly easier but you'll want to get it fit over the top right and left edge so it doesnt slip down when pressing it.
I havent had any issue with mine since fitting and find it really enhances the look. Good luck and post a pic when you're done! (y)
