Camera screen green
Bob A
Scotland
HS PHEV
Has anyone come across the problem of camera screen turning green.
I can still switch between cameras but each selection results in a green screen.
The rest of elements on the dashboard screen are functioning as normal and I can select camera but nothing but green visible on any camera selection I make.
Any advice would be welcome if there is a simple fix, otherwise I will have to book the car into the dealers.
Thank you in advance.
Yes, this problem has been seen before: Camera green screen
I have had the problem twice in the approx 4 months since I had the car. If you switch the car fully off, and then wait a while (more than just a few minutes, but typically an hour should be fine) then restart the car, the green screen will go away.
Annoying, but (for me anyway) relatively rare.
Upvote 0
Just found the other threads.
Sincere thanks for your advice.
I responded to earlier thread once I found it and your advice appears to have solved my problem.
Again, thank you.
Upvote 0
No problem. Both times it happened to me was in bright sunshine on a warm day. But equally it does not always occur, even on the hottest day, so I'm baffled why it suddenly occurs.
  • I'm not concerned enough to raise it with my garage at this stage.
Upvote 0
