- Aug 7, 2019
- Location
- Birmingham, UK
- Not an MG
I have three (off topic) points to make in response to your post and that which you replied to.Sorry for not being knowledgeable about every aspect of the car. Clearly not as clever as you. If everyone knew all there was to know about the car then forums like this would not be needed. I raised an issue that I thought would be of interest to many. Having looked at the MG handbook again I can see that there is no direct reference to charging to only 80% or indeed any specific way of limiting any charge other than by monitoring yourself and unplugging when appropriate. I had done research but silly me I did not have all aspects of the car to hand. Some of the issues raised on the forum were ones that I knew about, but I resisted the temptation to belittle those that raised them. I have owned a NIssan Leaf EV for nearly 2 years before buying this MG5. These are not bragging rights just facts. I learnt much more about the car after purchasing it, even though I had done research before purchase. I still did not know everything about the car. I am now in a similar position with the MG. I am learning and will continue to do so throughout my ownership. I shall have to give very careful consideration before asking any questions on this forum again.
First, not knowing about not being able to limit the charge to 80% is somewhat of a novice omission nowadays, but then there is nothing wrong with being a novice as we all are at first.
[Incidentally having an app or system to limit the charge was not an option on my first EV in 2017, so someone could be an expert EV owner, but just not do sufficient new research when looking at a new car.]
What happened here is that you declared yourself as not exactly a novice
But then talked about making somewhat of a novice mistake when researching the ZS EV and then criticised MG.As I said I am not exactly a novice in the EV ownership stakes
You must understand that this being an MG forum, while there are plenty of reasons to legitimately criticise MG and their cars (no company or car is perfect), doing so in this way is somewhat likely to invite an unsympathetic response from other MG owners. So you shouldn't be surprised at the reply you got.Once again bit of a fail for MG
Which was, I think, a tad tough, but not unreasonable.You say you are not a novice in the EV ownership stakes, and then criticise MG for not being able to limit a charge to 80%. Did you not do the appropriate research first? If not, the fail is with you. And apologies for being so blunt, but I am a complete novice with EVs, but I did know this limitation before I bought the car. It was pretty easy to find out.
So my second point is that people who engage in public forums need to be able to take some (appropriately put) criticism. Call it a 'thick skin' if you like. Although insults and disrespect are not tolerated here.
You shouldn't get so upset at the reply, though you did and reacted.
Third point, the passive aggressive part of your reply was not helpful.
andSorry for not being knowledgeable about every aspect of the car. Clearly not as clever as you.
I would hope that folks consider all the messages they post, though nobody should be afraid of asking a question in fear of it being considered 'silly' because we are all novices at first. And poking fun of novices is not tolerated here. They make up a large proportion of our visitors.I shall have to give very careful consideration before asking any questions on this forum again.
@SDP79 everyone makes mistakes and it was good that you admitted yours. First world problem, though, and I've lived happily with my Ioniq for over 4 years without the programmable charge limit feature.
Correct that the original ZS EV doesn't have the feature, though I believe MG have fixed this (not a mistake, but) feature deficiency for the refreshed model available to order now.
