paulpk
My car charging points in rear passenger not working?
Are the fronts ones working or not, I will hazzard a guess at a blown fuse worth checking out first.My car charging points in rear passenger not working?
Hi again, found this on the MG website in the owners handbook for the MG5 LR page 236 which you should have, appears to be at F2 a 5amp fuse for the rear usb charging ports. Hope this helps.Yes front working
That shows that the fuse also covers the interior mirror, which I interpret as rear view mirror, so is the green light on the auto dipping mirror on, or does it come on when you press the on/off button for it.Hi again, found this on the MG website in the owners handbook for the MG5 LR page 236 which you should have, appears to be at F2 a 5amp fuse for the rear usb charging ports. Hope this helps.
Les.
Yeh Gomev is right to point that out, but the auto dipping mirror with the little green light on is only on the exclusive model and not the excite I believe, so it depends on model.That shows that the fuse also covers the interior mirror, which I interpret as rear view mirror, so is the green light on the auto dipping mirror on, or does it come on when you press the on/off button for it.
Les.
