Car stuck ON and wont shut off
melaidhrin
sweden
ZS EV
When trying to start charging today, it failed. when i was going to move over and try another one, the HV battery disclnnected, and then the car is stuck in ON-mode, but cant drive. Lights are on, infotainment panel is working. But cant turn it off.
Any ideas?
Keep foot pressure applied to the foot back until you get the READY bong.
Release the pressure early or using the gear selector early and the car will complain ?.
This is REALLY annoying. Most the time is fine, but sometimes a slight change in pressure and suddenly none of the radars work and you're screen is a christmas tree of warnings.
Upvote 0
Just slow down slightly and follow the start up process, without cutting corners and all will be fine !.
Rush or cut corners and the car will complain violently !. ?.
Upvote 0
This just happened to me but without charging, reversed out of garage and tried to put in drive then car just stopped and wouldn't change gear or turn off. Would only go into park or neutral no messages or errors.
Upvote 0
How did you get it back to work?
Upvote 0
It happened to me once but I’m sure that it was my fault.
I think that I did something in the wrong order.
The advice that you have already received to not to panic wait a minute
and start the procedure again.
I just opened the car door closed it and started all over again.
It was fine.
Upvote 0
