Richy Rich
Hi All,
I've been looking at these forums for a while but never had anything to say, until now.... I've made this post entitled "Car unusable. Possibly battery failure or electronics issue. Advise sought..." hoping people might be able to come to my aid.
A brief bit of history:
I have a MG ZS EV, about 1.5 years old. For a while the range has dropped much quicker than expected (or the car predicts), usually giving about 60% of the suggested range overall, on normal mode, driving partly at 30 mph and partly with the ACC at 65mph tops on dual carriageways. I figured this was bad, but thought that maybe this is normal and anything over 30mph causes the prediction to be wrong. Recently, when I 'fully charge' via the 3 pin plug, I am told I have ~ 128 miles. With the standard charger it gets to ~160 miles. Again, maybe this is normal as the 3 pin can deliver less power.
Anyway, what happened recently was that I had a 21 mile journey to make to the airport. I had a range of 58 miles and figured that I would fast charge on the way back home (a mistake, in hindsight). Knowing my car, I knew that I would have to charge like this, but knew there was a fast charge station very close to the airport so it would be ok. So, even with driving carefully, mostly at 50-55 mph) the range plummeted, and at ~25 miles range (4 miles from the airport), I got red battery warning telling me there was some sort of failure, and it also stopped doing the regenerative charging (with errors for this as well). I then got consistent warnings and power drops as the range fell away and periodic power drains were repeatedly implemented (I think this is normal on low battery) and figured that I would head to the fast charge point and give it a boost before continuing to the airport. I had some time spare for this...
So, then the car would not charge via the fast charger, I was told with a very fast message flashup that the charge wasn't authorized. I tried all sorts of combinations of when to connect and lock the car etc., and used a 2nd charge point but still, it would not accept it. For info - I have used them before, although not at that site). I have this car through my work, so was able to call to have the car recovered to my property, while I headed onto the airport to catch my flight. It was dropped off and started charging.
The current issue:
When I come home and try to move the car, I get a stream of warnings telling me that all sorts of warnings/faults have come up, and the gear/drive selector will not select a gear - it doesn't light up. The faults are ABS, Stability control, Traction control, Autohold, EBP system, Hill Decent Control, Hill hold unavailable, LKA system unavailable. I've attached some pictures to show this.
I tried starting the car by holding down the power button, but then I found that I couldn't turn the car off.... I had to hold the power button down again to do that and cycle the normal process to get it off properly. I've also tried disconnecting the 12V battery for an hour to see if that helps to reset the process, but it doesn't.
So, I'm not sure what is wrong, not how to fix the issue I'm currently having. Any advice would be gratefully received.
Kind regards,
Richard
Edit - Car is working again. For anyone with a similar issue, reading through this topic may be helpful. For a quick fix, manually disconnect the handbrake, and then move the car a little, then restart the car and all should be good. Possibly your 12V battery needs charging. If you're having a similar range issue, you might have got bad BMS software and require having it put right at the dealer, and may need to do some long charges (after fully charging) to right the battery as well. Thanks everyone.
The current issue:
Kind regards,
Richard
