It looks a bit slow. If you multiply the voltage with the amperage you get the number of watts being supplied.I have a charge amperage of -50 amp on the cars display and 4.3kwh on the charge ‘pump’ display.
Is this the normal for CCS rapid charger ?
If you went from 106 miles to 186 miles of range then you were probably at more than 50% state of battery to begin with.Attached are the charging details from BP. So 23.5 kWh used in 1 hour. So about 5p per mile, going from 106 miles to 186 miles.
I guess that as the charger was in a pub car park it may be supply capacity limited and can’t supply at 50kwh.
thanks for the calculations
Good to know, thanks !If you went from 106 miles to 186 miles of range then you were probably at more than 50% state of battery to begin with.
Rapid chargers charge quicker at lower battery percentages. The fuller the battery the slower it charges.
So 23.5kw sounds about right. If you were at about 10-15% charge you may have gotten the full 50kw. For a while at least.
