carol16
I have a 2022 ZS Trophy LR with approx 3500 miles on clock, and a 3.5kw Pod Point home charger (used to have Ionic PHEZ). Recently, when charging it will randomly stop. Sometimes it can be after 30 mins, or several hours, or it will complete a successful charge with no problems at all. I have noticed when checking the app that the charge rate is normally about 3.2 ish or thereabouts, but have seen it well below this, 2.5 or even lower and assume this may be the problem. 2 questions; will the car stop charging below a certain charge rate? Secondly, is the problem likely to be the car, or the charger? I have charged once with the granny charger and that was ok, but normally with my pod point and it's been ok. Unfortunately, last week when the issue arose again, the ismart app wasnt connecting so couldnt see charge rate..took 3 attempts, half an hour, and hour and a half and finally successful 8.5 hours to charge from about 55% to 100%! Purchased the car last October, and absolutely no issue until about May. Never used rapid charger as only pootle about locally, and only charge a couple of times a month, and do an equalizing charge every so often. Sorry if similar has been asked before, couldnt find anything by searching. Thank you for any help (very basic explanations appreciated, as not at all technically gifted)
