Simon 19662021
I picked the car up yesterday,I have a EO charger and I am on Ocypus Go,so how do I set the charge to 80%,it just keeps charging for the 4 hour slot?
You do know you're supposed to charge the battery to 100%, then some, to balance the cells once a month ?I have managed to get my charger setup in order for it to only charge the car to 80% but it is not a straight forward process and this probably won't be of much use to you but thought I'd share anyway.
I've got Torque Pro installed on my phone and a bluetooth dongle in the obd2 port so I can pull SoC while I'm in the car. The log files from this get sent over to my home automation system so that then is made aware of the last known state of charge.
I then have my granny charger on a smart plug with energy monitoring so I can control when it charges and measure how much energy is delivered to the car. It then cuts off when it's delivered the amount of electricity needed to get it up to 80%.
Which automation system do you use? And how do you let it know the SOC?I have managed to get my charger setup in order for it to only charge the car to 80% but it is not a straight forward process and this probably won't be of much use to you but thought I'd share anyway.
It’s a bit “Caveman” - but you can get near to a SOC of 80% if you can set a finish time on your App.I picked the car up yesterday,I have a EO charger and I am on Ocypus Go,so how do I set the charge to 80%,it just keeps charging for the 4 hour slot?
It's in the manual.
How does the app end the charge? Which app?It is easy to work out how long the car needs to be on charge to hit 80% and then set the end time of the controlled charge to end there on the App.
The “Sonoff Wi-Fi” relay only controls the low voltage signal to the car via the communication device in the dumb wall box.How does the app end the charge? Which app?
I hope it doesn't end the charge by opening the EVSE relay under a 7 kW load driving a PFC stage (huge inductor will cause a massive arc on turn-off). Hopefully, it stops it at the car end, or if at the EVSE end it drops the control pilot first before opening the relay.
Just curious, aren't going to do this myself - though I have several different sonoff modules for other uses.The “Sonoff Wi-Fi” relay only controls the low voltage signal to the car via the communication device in the dumb wall box.
When commanded, it sends a signal to pull in the contractor in the wall box
It is not switching the full 7kw load from the supply.
The “App” is a free to download software available from the App Store etc.
It been produced to control the Sonoff range of switching devices.
It gives you the ability to set start and finish times from your phone etc.
When plugging in the ZS EV and the charge commenced, the dash panel will report the SOC of the battery and give a time of how long it will take to hit a full 100% of charge.
If you only want to charge to say 80% you can finish the charge at a time to suit your requirements.
Working on the theory that a 7kw wall box will put roughly about 25 miles of range into the battery every hour.
It is fairly easy to control the finish time to achieve a lower SOC of a chosen %.
I have a 16amp Sonoff inline with an external socket that I can use with a granny charger. As well as scheduling, it records power used and it can be configured to turn off when the current drops to a set level.The “Sonoff Wi-Fi” relay only controls the low voltage signal to the car via the communication device in the dumb wall box.
An interesting work around.I use a combination of EMON cms and openhab, I use EMON for tracking/logging and OpenHab for the interface.
I have Torque Pro set to log to files, then this file is sync'd to my google drive using an app called drivesync. Then I have a python script on my Emon host that checks for new files, reads the contents and uploads the data to Emon.
To get the current state of charge I take the plug's total energy use when I last got a file update vs what it is now and add that onto the last know SoC.
There are some concerning videos on YouTube showing 16amp Sonoffs are not quite man enough! I use one to control my immersion heater (on/off) under Alexa voice control - however, I get the Sonoff to control a proper contactor which is able to carry the full current for a long period. I also recall that the Sonoff only switches the live? So that‘s a concern.I have a 16amp Sonoff inline with an external socket that I can use with a granny charger. As well as scheduling, it records power used and it can be configured to turn off when the current drops to a set level.
Shame they don't do a 32amp / 7kW version.
I have a number of the smaller inline ones and some socket ones, which I only use for lighting / low power use.There are some concerning videos on YouTube showing 16amp Sonoffs are not quite man enough! I use one to control my immersion heater (on/off) under Alexa voice control - however, I get the Sonoff to control a proper contactor which is able to carry the full current for a long period. I also recall that the Sonoff only switches the live? So that‘s a concern.
The 16 amp rated “Sonoff” relay is over rated for the job that it is performing in my 5 year old dumb Rolec unit.Shame they don't do a 32amp / 7kW version.
