Charging!!
bissu
Finland
Marvel R
If you guys are chagring in ccs what's the best pick in your guys car? In winter what temp was and in summer
Atm I'm charging in 150kW with no other car, I had 53% all cabin heated for 20min high voltage also used while driving driving took 10-15min and now I'm getting 30kW max.
Have you guys try any method to chagre and or it takes bit high kwh? Cuz normally car stop taking high charge power after 80% SOC. Idk what is MG's problem when it comes to charging cuz can't really see what things are taking kW or what is happening only phones shows charging power nothing else.
The charging power limit is not due to other electrical loads; those are tiny compared to the main battery charge power.
The problem is that MG' s battery technology can't safely take the higher power without damaging the battery cells through over-voltage or over-temperature. Hopefully that will change with solid state batteries arriving in the next few years.
Never seen more than 70 kW ever on mine. I get that in Summer. After 80% the charge curve slows down on most EVs.
Mine charges slow on DC charging now in Winter also, even if you preheat the battery 1 hour before charging.
MG need to step up their charging speed on newer models they are last on that if you compare against other Chinese cars like Xpeng, Nio, Byd.
Let's be fair mg need to step up in everything idk what they are even doing with the car and the software I had mg for 1 year now ngl the car made me speeches when I chat with other about ev car there isn't anything good in that car or that works that I can flex with other Evs 🤦‍♂️
