Clocks go forward charger
Vipar
Age
83
Bexley
Do I need to change the timer settings because the clocks go forward tonight? Ohme wall charger
I'd be surprised if anything (with integral, sophisticated electronics) designed and manufactured in the last 10 years or so needed manual intervention when the clocks changed.
Last year that's exactly what happened with my Easee One charger, perhaps that's just particularly poor on the software front, as one might perhaps guess from the name. Hopefully others aren't as bad
I will probably know in the morning thanks for the replies.
I'm with E.on and they say the EV tariff runs from midnight to 7 am both in BST and GMT.
Just checked on my Zappi app and that has updated to BST so has the wall box and the car.
I am on Octopus "economy 7" - that system uses UTC time and therefore I need to change the charge time on my car to 1:30-8:30am and I have to reset the Growatt battery charging as well. I do not know if you are using other tariffs if the same issue applies. If you have HomeAssistant - you can easily track the unit price of electricity. Yes - I know I am not on the best tariff - but the combination I have gives me 15p/kWh export and I only have a granny charging plug - so I need the 7hrs!
My Wallbox Pulsar Plus was set up with 00:35 to 04:25, the low tariff times for Flexible Octopus, and the times were changed from 00:35 to 02:00 after the Spring clock change - not ideal. However it's only twice a year to have to alter it.
