MG5 2022 driver
It should work on a new car regardless and it may be an indication of problems elsewhere if the problem is hard/firm wareWhy are we persisting with the car's built in Sat Nav?
I don't get it ?![]()
I think it just indicates that MG are way off Google with a Nav system ?It should work on a new car regardless and it may be an indication of problems elsewhere if the problem is hard/firm ware
Thank you. Simultaneously with the car Satnav showing the car in Brussels, the MG app on my phone showed the car at the correct place so I was thinking that the GPS and Satnav are different systems.I have seen the car show the centre of Brussels as its location. This seems to occurreif it hasn't got a good GPS signal. Usually fixes itself after a few seconds when a good GPS fix is found. Maybe your problem is the GPS receiver fun tion?
It will be a HQ position.Interesting point..... I wonder what the significance is of the address in Brussels?.... Could it be the software developers address?
And with Google maps you will find you are not driving over green fields as new road appear. ?It will be a HQ position.
The in built Nav in my Golf used to revert to Wolfsburg in Germany every so often.
Use Google Maps folks!
I have have similar problems on my Gen 2 ZS trophy. It’s been back to the dealer twice, they say there is no dead reckoning on this model. They rebooted the software but no improvement .It can be hard to search for something when it can have so many names.
The answer is to turn off dead reckoning; see for example
ZS Long Range sat nav not updating
Hi all, Any one with the face lift having problems with the built in sat nav. When I start the car the location is right. But when I start driving it doesn't show any movement on the map. I use carplay so not a big deal but wondered if anyone has had similar issues and if they managed to fix...www.mgevs.com
They need to take another look though the menus in the head unit again !.I have have similar problems on my Gen 2 ZS trophy. It’s been back to the dealer twice, they say there is no dead reckoning on this model.
Go into Sat nav settings and take off dead reckoning. That should sortMorning all,
I collected a new Black Trophy Connect SR from the boys in Chorley at the tail end of last week. Drove it back to Swansea and using ABRP made one 20 minute stop to charge at a rapid in Ludlow. No problems at all. Arrived home with 23% remaining. Great!
I am finding the car very impressive, comfortable to drive and I am using everything I need to (HVAC etc. with AC on and set to 21-22 deg.) without worrying about range. For me, it is there to be used. If I have to make a stop to charge, I will choose a rapid and make the stop, grab a coffee, use the bathroom.
As I mentioned, coming down from Chorley to Swansea (about 185 miles total through central Wales) I was using the ABRP through Android Auto and connected to the car. I didn't use the cars own satnav.
Starting yesterday, I tried out the cars satnav just out of interest and it the screen came up with my current location. After moving off, it stayed at the origin location and didn't move. It was basically frozen. I am able to move to other screens and everything else works as it should. Did it again this morning.
Has anyone else had this issue? I haven't contacted Simon at Chorley yet but will do if this persists.
As a point of interest, the last day or so has also seen, when getting ready to move off, the "HV Battery Disconnected" shows and I have to press the start button to shutdown, and press again to start. Is this also something someone has experienced and connected to the satnav issue?
I have searched on this site and also in Google but nothing close comes up.
Thanks,
Andrew
Remember to reset info by pressing the physical home button for approx 10 secondsGo into Sat nav settings and take off dead reckoning. That should sort
Dead reckoning doesn’t take into account local environmental issues, traffic, weather etc, or so I think I understand ?What does dead reckoning actually do and why is it there if it causes problems? fwiw I don't use the onboard satnav, I tend to use Waze through Android Auto but I know the wife will use the onboard when she needs it.
Only had our ZS for a few days, but the inbuilt satnav showing charge point locations, for me is clearer/larger than Google and Apple maps connected via my iPhone, nicer voice to-boot ??I think it just indicates that MG are way off Google with a Nav system ? has
I just found the UI to be terrible and the bit that actually matters (the routing) to be not as good as Google.Only had our ZS for a few days, but the inbuilt satnav showing charge point locations, for me is clearer/larger than Google and Apple maps connected via my iPhone, nicer voice to-boot ??
