Cyberster suspension
Juhani
Finland
Cyberster
Is anybody little bit unhappy with rear damping in GT. I think its too sloppy front is fine and goes over any jolt without issue but rear no.
I think that rear spring rate is quite good but shocks dont control up movement sufficiently, maybe compression damping also could be stiffer. In speed cornering rear starts woble and looses traction. Adjustable Koni or Billstein territory but not yet available. If 26 has uppgrade that should be covered in warranty, I complained about this in first 1000 km
Please can you post the link of where you found out about the 2026 update. Thanks
2025上海车展:MG Cyberster新款来袭_哔哩哔哩_bilibili. Its in chinese.
I completely agree. Fast corners are really wobbly. I am curious to see if there will be a fix for this problem.
As far as i know, only AGT invertered coilover is in testing phase for this car.
I totally agree. Especially bad on roads that feature rapid, repetitive undulation (small elevation changes occurring every few meters, creating a wave-like surface).
Online I found info about a company "Gusto Engineering" that mounted a Ohlins Road & Track suspension with Eibach springs. But besides some pictures, not much info to be found.
Gusto Engineering
I totally agree, the rebound is too high on bumpy roads.
I found some information:
Since the spring is separate from the shock absorber, it should be relatively easy to replace the shock absorber with a more efficient component that has rebound adjustment.
