Dashcam Installation (Viofo A329 2CH) - Hardwire Kit
shiremail
Germany
ZS EV
Hello together,
this is a rather technical question. I ordered a dash cam from Viofo (A329 2CH). I would like to have it connected directly to my car, so that it can record the surrounding area while it is parked (park mode). I found a company here that would do it, but it is not really familiar with the MG4 I own. I already supplied the workshop manual, put - according to the technician - it does not really provide detailed information for the following two questions:
1. Where can the hardwire kit get continuous current and
2. Where can the hardwire kit get ignition current?
Links to the dash cam and hardwire kit:
Can you give me a hint on how to connect it correctly?
Go to this board:
and do a Search of This Forum for dash and you'll find lots of results, such as:
Not to be rude, but does your technician not know how to use a multimeter?
The MG dealership linked the ignition current to the headlights on my MG4, but during a later install of a secondary battery the technician changed it to "the normal location", not sure what that position is though.
Hello together,
there is an OBD port under the steering wheel, get a switched OBD dashcam cable from Amazon, the switch gives ignition live or permanent live, depending what you need, ignition live gives power for 15 mins after ignition off.
The roof lining has lots of room to store excess cable, I ran the rear camera cable under the floor carpet as on previous card the dab radio aerial is under the roof lining and cam cables cause interference. All done in 30 mins.
