okohll
Noticed my Easee One charger had changed itself to start charging at 11:30pm today instead of 12:30am when my cheap rate electricity starts. The end time moved forward too I think but whilst editing that fixed it, whenever you tried to change the start to 00:30, it reverted back to 11:30pm. Eventually I worked out if you set the start to 1am it did save ok - losing 1/2 an hour of charging but at least running in the cheap rate.
Actually scratch that, it hasn't saved properly at that either, it now says starting at 00:00. I guess the only thing to say is it's very buggy. I'll try a 2am start.
This is unlikely to help anyone now but may be a reminder to check the schedule next time the clocks change.
Not a big issue to use an hour of normal rate electricity (assuming it goes back to normal tomorrow that is), just slightly annoying.
