Did you buy your EV to Save The Planet?
Think you've just picked out the 'family' trim model there. In total, looks like around 47,000 ID.3's sold in UK and just over 500,000 worldwide :unsure:
yeah, sorry it was a lazy AI answer. I didn't take the time to think it was improbable. I will say I see more MG4s than ID3s around here and I was put off the ID3 with the reviews slating the clumsy software, haptic controls and not up to VW standard interior.
I followed an IM5 up the A64 the other week. My gawd that butt end is so ugly in the metal.
Each to their own, I suppose. Personally I like it. 🙂👍
Is it me, or has it got a slight look of this,
from the, rear. (Use your imagination)
Obviously the AM is a better colour. 😉🙂
The rear window is similar ..... and neither of them have headlights at that end, that about the end of the similarities as far as I can see
T1 Terry
T1 Terry
As you say, rear window, similar.
The curved rear lights, similar.
The rear haunches, slightly similar.
I did say use your imagination. 😉🙂👍
Maybe they'll get this ammonia to hydrogen conversion down to a light and small package that they can feed it into the jet engines and just produce water as steam that will improve the thrust. The fuel tanks can be replaced with light weight graphene reinforced polycarbonate that doubles as the wing outer skin and the baffles in the tank double as the wing structure ribs.
That way, they can both offset the weight difference between aviation kero and ammonia while increasing the tank capacity ..... eliminate the fire risk and just worry about the ammonia killing who ever in the case of a spill or crash .... the ammonia is an energy carries and the remains after the hydrogen is again extracted, is nitrogen, the most abundant gas in our air and great for putting out fires and as a plant growth stimulant .... The role of ammonia in reaching net zero
The down side, it does have a short life cycle in the atmosphere, but unfortunately it converts to N2O (nitrous oxide) which is 275 times worse than CO2 as a greenhouse gas ....
T1 Terry
And water vapour is 10 times worse than CO2 as a greenhouse gas (in its basic form)
Yes. I guess like most people you didn't realise water vapour can be a powerful greenhouse gas.
Increased water vapour (aka clouds) is a response to global warming. Not a cause of it.
The outcome of the increased water vapour in the atmosphere as a result of the increased temperature driven by the increase in CO2 is increased rain as seen by historically high flooding events.
Thankfully using EVs rather than ICE cars helps transition us away from use of Fossil fuels, but there's much more to do.
Clouds are definitely a blanket! clear nights are much colder than cloudy nights. However, clouds also reflect the suns rays back into space, so you get cooler days. I don't know what the net effect is.
I have a feeling humidity level, (water vapor in the air with out cloud formation) has little effect, it's only the reflectivity of clouds either up or down, that has a major effect
A greenhouse gas allows heat in, but traps it from escaping out into the upper atmosphere where it can dump the heat out into the great beyond via thermal radiation, it's a vacuum so no conduction possible.
Water vapour will absorb heat from above, and trap heat below, but it will not allow the heat to pass through it to reach the ground because water can absorb three times the heat energy of air, but it also traps the heat below the water vapour in a very narrow around between the land and the upper cold layer.
Planes fly above the clouds, it might be raining under the cloud layer, but bright sun above it .... but it's not hot above the clouds, yet it can be quite warm below the cloud line.
That doesn't make clouds part of the whole greenhouse effect, more likely to cause an Earth surface reduction in heat over time because the heat absorbed by non-reflective surfaces aren't getting heated ..... nothing is hot to the touch under a cloud covered sky the way it is without the cloud cover ... particularly here in summer Australia ......
T1 Terry
Yeah, but it doesn't matter much because our human activities don't generally impact the total amount of water vapour in the atmosphere. Water is just cycling and moving around all the time.
Increasing CO2 and methane, though, is making a major difference to the atmosphere.
My wife liked the blue colour. The rest of the specification and comparisons became the subject of research by me over the next couple of days
Ya, think? Fair enough. Beauty is in the eye of the Beer-Holder. 🙂👍
Indeed it is, it looks okay in pictures but in the metal it was literally butt ugly in the grey. That rear window is so narrow....
