Display time discrepancies
MacG
UK
Not an MG
Can anyone give me a pointer, clocks went back last night. The infotainment screen displays the correct time but the dash is an hour out.
I have driven the car for around 20 miles and it hasn’t updated in sync with the infotainment.
When I checked the time clock in my car his morning, it was reporting 1 hour out.
It had not automatically updated.
Went into the settings in the head unit and reset the time clock manually, to the correct time of day.
When checking the settings, it was already set up to automatically update the time clock, but clearly it had not done it, for some odd reason ?.
I was in the settings, because I wanted to adjust the start and finish times, in order to take full advantage of our 5 hour cheaper rate off peak tariff.
It was the same in my previous VAG car.
I had to set the clock manually, even though it was set up to automatically do it ?.
I will check it again in the morning, just in case it decides to update itself late ?.
When adjusting the time in the head unit, it makes the same time changes in the dash panel.
I don’t want the car charging outside of the 5 hour cheap rate tariff, because it is very expensive !.
If you have not used your car today, make sure the time clock has updated !.
This morning my wife said the clock update by its self but when she put a destination in the sat navigation the arrival time was 1h out Still
Just checked and time is fine but I put in a destination at 1825 and it says arrival at 1730 for a 5min trip so its gone the wrong way?
The weird thing is that the one displayed on the Infotainment screen is correct but the one on the dash display is out. I had thought they were linked through the computer
Have you tried the reboot of entertainment unit push and hold the physical home button till it reboots?
Was only asking as when you do that all sort of stuff go's off and on on the dash was thinking clock was linked
