Does not charge above 40%
MarvelousR
Netherlands
Marvel R
Just brought my car to the MG garage. It turns out that my car does not charge above 40% (used different stations, speeds and passes) since a few days. Has anyone else had this problem? And what was your solution? The timing is very inconvenient, I was supposed to leave for a car camping holiday tomorrow afternoon. 🫣 The garage will read the data first thing tomorrow morning...
Nope, that's not it...
Upvote 0
I assume you didn't check it before you took it to the garage, I still think it is the most likely. I had it happen to me were the car didn't update when I changed the app setting.
I leave mine on 100% now and let the charger control everything.
Upvote 0
Ah, is this a well-known bug? Turned out that indeed the car had a charge limit of 40% all of a sudden. 🤷‍♀️ Luckily an easy fix and happy to know where to check if a similar thing happens again.
Upvote 0
Generally people had it happen, also on the discharge limit setting (V2L) where the set limit isn’t always enforced and another limit overrides. Anything new on your side?
Upvote 0
Similar threads
