Does the MG3+ struggle with hills?
Whoopedoodaa
Northants
MG3 Hybrid+
Returning home in my MG3 Hybrid from North Wales on the three lane A55 expressway (in severe rain) when I reached the Rhuallt Hill with its 10% gradient, when I accelerated to go up this steep incline the engine unnervingly 'flatlined' for about 5-6 seconds before then accelerating as expected. Was this malfunction the engine undecided about what gear it should be in, or was it looking for additional power support from the battery, bearing in mind I had been driving for more than half an hour at 50-60mph on this carriageway without any cause for regenerative braking to load up the battery? Has anyone else found their MG3+ faltering while driving uphill with this hybrid pairing?
Have you seen our previous discussion on going up/down hills @Whoopedoodaa
Thanks Clive. Here's an answer to this issue I found on the internet bearing in mind my issue came about on only a 10% incline!
The experience you described with your MG3 Hybrid's engine 'flatlining' could be related to the hybrid system's performance on steep inclines, particularly when the high-voltage battery is low. It appears that when the battery's charge is depleted, the combustion engine might struggle to provide sufficient power for climbing, which could explain the temporary loss of acceleration you experienced. Additionally, the regenerative braking system is designed to recharge the battery during deceleration, not while maintaining a consistent speed or accelerating, which might contribute to the lack of battery support in such situations. A software update has been known to resolve similar issues, so it may be beneficial to check if there are any available updates for your vehicle.
Hmm, we live at 986 feet and so far it has shot up from town which is 34 feet So a good climb in less than 1 mile.
Measured at one mile that's a steep incline of 18.02% so it is a good job you had some recharge in your battery to assist the engine.
I fortunately live in an area which is reasonably flat, (north Cheshire/South Lancs), so I've not experienced any issues with hill climbing. I am wondering, though, if anyone has had issues climbing the winding, steep access roads to multi-level car parks? Or would this relatively short distance not cause the same problems?
This is the type of problem that happened to me and confirmed by the dealer. The official response from the importer was if this symptom occurs, the driver has to press the accelerator pedal to the maximum (kick-down). If it still does not work, the engine computer must be updated. They also mention that the solution is temporary and they will try to find a permanent solution. In two weeks I will find out if the update solution is definitive or not.
I have managed multistory car parks with no issues other that a user error of removing my seat belt to take a ticket (mismatch of arm length v distance to ticket machine due to awkward approach angle on top of ramp). The seat belt removal meant that the auto hold would not disengage, when I went to move away. But no issues with loss of power.
Thanks Declan. That's taken the worry about visiting Multi-storey parking.
Last month we were in Somerset and we went up Porlock Hill twice both times we had this problem.
Not quite correct. Regeneration will charge the battery when you lift off the throttle or brake. Additionally, when the battery becomes low the engine will charge the battery as well as powering the car. This is causing the problem going up a long hill. I think a software tweak is needed to stop the battery charging when the load on the engine exceeds a certain value so that all available power can be sent to the front wheels.
Agree with you...but let's not forget we have to drive with min. 37 mph allowing engine to engage the gearbox in first stage
I get this problem all the time as I am in a hilly area but my dealer won’t acknowledge an issue. Does this update have a name or something I can refer them to?
Yes just brought a new MG3 Essence Hybrid+, only 500km driven and on our first attempt to drive over the Gillies Range in the Atherton Tablelands our car lost power and revved erratically, lost speed and we had to pull over for safety concerns.
you need to do the update,
you'll see that then, everything will be fine.
Some problems are common to all full hybrid cars.
I had a strange thing happen, I was going through a village when the car in front stopped so the car slowed to a stop as it would with the variable cruise control, the car pulled around the corner and I pressed the button for the car to carry on, and it did, but on my route just around the corner was a long hill going up, the car was increasing in speed until it got to about 30-35 and I was about a third of the way up the hill, and then nothing, it just would not pull anymore, so I was doing about 30 in a 60 with a rather long queue behind me, i tried increasing the speed via the button, but nothing, so I ended up having to put my foot flat on the peddle and it eventually decided to go, and wow, did it shift, it had EV power available, as well as ICE, so I have no idea why it refused to go above 30-35 unless I manually put my foot on the peddle.
