Driving in EV mode almost all the time - Any issues?
Captin1234x
Age
61
UK
HS PHEV
Hello, have had my fantastic MG HS PHEV for almost a month now and wanted to check something out. I am spending almost all my time in EV mode (great) and each night I top up the battery to 100% in readiness for what the next day might bring. My questions:-
  • Is topping the battery each night to 100% likely to increase battery degradation (long term question)?
  • Should I run the engine periodically?
TIA
Hi, Sorry can’t advise but I am awaiting delivery of my car but have the exact same questions so thanks for raising so succinctly. I await replies with interest.
Upvote 0
Hi. I have a similar situation. I don't know if it is a good idea, but I too charge up to 100% probably every other night. The only downside I could come across was the issue of petrol degradation. (I now have had the same petrol in my tank for 3 months) So I guess using some petrol from time to time might be something worth considering........online info.>
"Modern petrol does degrade over time. It starts to degrade from the moment it's put into a container, and its quality will decline significantly after a few months, even in a sealed container. Factors like temperature and contamination can shorten this lifespan. While petrol in a sealed car tank or at a fuel station forecourt will likely remain fresh for at least six months, older fuel can lead to poor starting and uneven running".
Upvote 0
Hi. Also running mine in EV and a charge last me about a week going to work and back, when charging upto 100% each time. Not sure what the long term outcome will be but so far so good. I have also recently done a long trip manly in HEV mode.
Upvote 0
With regard to petrol remaining in the tank, before I picked up the car I was advised to use Premium (Super) Unleaded rather than just Unleaded so that it remains in as good a state as possible. I got the car in February and I have still only fuelled it once, with 57% of the tank still remaining. As mentioned in a different thread, I am shortly going away for a few days without the ability to charge the car, so it will help use up and freshen the fuel stored in the tank.
Upvote 0
Charging to 100% every other night or even every night, for that matter, is fine.
As for the fuel in the tank, I have heard that petrol, does go off, usually 6 months or so, probably mostly on cars that never move. At least your fuel is moving about in the tank, and not settling. Can't see you ever having the same fuel in the tank, for months on end.
Upvote 0
Car fuel will start to go off after a few weeks, but that said, not to the point of it not 'working'. I'm sure many of us went through a similar thing during the Covid lockdowns.
Aviation gasoline has to remain in spec for 6 months. The theory is that car petrol normally is used within a few weeks so there is no need to making it 'last longer'.
I have a small boat with a petrol outboard motor and the fuel in that is standard road fuel. We do however have 'fuel stabilisers' to add to the fuel. No idea if it makes a difference but the engine seems happy even after the fuel is 6+ months old (it's a 200 litre tank and sits there over the winter.
Via Google: STA-BIL Storage Fuel Stabilizer (4 Sizes)
I haven't used the above product, I get mine from a marine chandlers - for no particular reason!
Ethanol can be an issue in the fuel as it absorbs moisture from the atmosphere. In metal fuel tanks, condensation can form, if the tank isn't kept full. Tests by Autocar showed that the better mpg with 5% ethanol offsets the higher cost per litre. Unfortunately, there isn't really and ethanol-free petrol out there now for car use.
Upvote 0
TIA
You can keep it in EV and put your foot down more than usual and the engine will be forced to kick in to give you the full 303bhp. Then it goes back to EV. I have one of the star buttons set so I can switch without going to the screen. Battery should be OK as your only charging at a slow rate.
Upvote 0
