AliveandKicking
- Jan 31, 2024
- Location
- Hilversum, Netherlands
- MG4 SE LR
If you set the setting for driving with 1 pedal on a fully loaded MG, this setting does not work, this setting only works when you apparently have 85% battery capacity. Is it correct that this setting is completely linked to energy recovery because it seems that if this setting works, it automatically stops at a traffic light (not an extra push on the brake to activate the parking) and brakes more strongly than the set value in regeneration.
It is a pity that he does not do "driving with 1 pedal" directly from a full battery or that that setting has to be activated every time at 85% battery capacity. In my opinion, driving with a pedal should always work and that the software, for example, will automatically regenerate at 95% battery capacity. I hope that MG will adjust this in the future
