Dumb question ( Climate control screen at start )
Pete1w
Sheffield
I've pressed a button....... Why does the climate control screen appear when I get in the car instead of the home screen? I appreciate it only takes a second to get rid of it but what have I pressed? I've been through every menu and sub menu and I can't change it. Please help.
Have you left it on the climate screen when you locked the car, I'm sure the screen it was left on is the screen it starts up on.
Yes as @Rolfe says, this apparently was a bug, although I liked it. I have this since they updated Foxy to R46 and I have adapted to the extra button press.
It is more annoying that the full heating screen comes up when you start the car or the AC and has to be manually dismissed. Would make more sense to go to the main screen.
Above from the Software Update thread page 180.
@Pete1w, do you know what infotainment version you have. My Trophy is on 1300R33, the HVAC flashes up briefly on power up occasionally but then is replaced by the Home screen.
My X Power does the same. Home screen is on, when I lock and leave the car. Climate Control screen comes on when I unlock the car and sit on the seat. It's always done that, presumed it was normal. Doesn't bother me at all. To be honest, I prefer that. 🙂👍
Oh and,
To the forum. And by the way, no question is Dumb. If you don't know the answer. 🙂👍
My car has always shown the climate control screen when I get in it. Always needs to be dismissed. I have always assumed it is in case people don't know how to get to it as they might be unfamiliar with the car and there aren't manual controls for all the settings. I'd prefer it didn't appear.
My Trophy 2022 (without driver awareness camera) always starts up on the HVAC screen, I can't remember if it did this before the software was updated to what I call the "my first HVAC screen" rather than the more graphical but admittedly harder to use original HVAC screen
I have never seen the HVAC screen pop up at startup (regardless of HVAC on/off). Always starts on Home Screen 1.
Mine always starts at the Home screen - and always has regardless of Info software version. I always leave HVAC activated, and since the last update I never need to adjust it. (Temp and fan speed can be easily adjusted anyway from the Home screen as there is an HVAC pane).
Ah, that would explain the difference - no HVAC pane on a Trophy by default, we get Weather I think instead.
    Votes: 1,014 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
