Electric battery lawn mower
I also got a Greenworks cordless one this Spring after having used petrol mowers for years. I was very pleased with this one - Greenworks 40V Cordless Lawnmower for Lawns up to 500m², 41cm Cutting Width, 50L Bag, Two of 40V 2Ah Batteries & One Charger, 3 Year Guarantee-G40LM41K2X.
It's weighty enough to feel sturdy but just light enough to lift up steps etc. Cutting is very good and the pickup / suction is excellent as many reviewers state. I use one battery for the front lawn and one for the back so no issues so far. Its easy to manouvre backward and forwards but not self propelled.
On offer at Amazon again today :-
I caved and bought that model last week, they had £50 off it so £199, which was nice..
Literally delivered today and charging the batteries for a weekend of grass action.
We replaced our aging petrol mower with a cordless one from Lidl as we already have several Parkside tools and batteries. Can easily mow front and rear lawn from a single charge of a 4ah 20v battery. Not self propelled, but it's so light in comparision to our petrol mower, it's effortless to push and turns easily. It was £49.99 without the batteries or charger (already have those) If you had to buy a battery and charger, then you would still pay less than £100
is it an OcuMow you have? ive been tempted for a while for the 18 but havent quite pressed the buy button.....
Hi Deviousrich, Yes it is the OcuMow18, great bit of kit and no boundary wires to faff about with, they do supply two magnetic no go strips to cordon off areas of grass (Ie newly sown patches)you don't want mowed. My grass has never looked so good.
good to know! if you dont mind me asking is your lawn flat? ours is slightly sloped so just wanted to make sure it would actually work
My grass is pretty level, I think it can operate on sloped lawns up to 35% (19 degrees) off the level. I would suggest you should look at the Cleva website trusted reviews.
The Greenworks got it's first outing today, not super impressed with it.
Part of the problem was my grass was a bit tough and long and tangled. I had to put it on the highest setting, anything lower and it just died. Roughly 36sqm lawn took more than one battery.
I've sharpened the blade and given it a little bit of serration to help it cut better and I won't leave it so long before the next cut so it should perform better.
I do like the height setting system, so easy to do and not having to drag a cable around was a big plus.
If the grass gets too long I have found it best to use the highest setting for the first cut, then reduce the height by one notch for each successive cut until you reach the lowest height that doesn't touch the earth. It's only a battery mower so it won't have the power of a mains model. Once you get down to optimal grass height it should give you better battery life - mine manages a similar grass area and strimming the edges on one heavy duty battery cycle.
Anyone who buys a petrol mower these days has rocks in their head IMHO. I just moved to a 1.4 acre property & bought an 80 volt zero turn mower. Priced at $10,000.00, I got it for $5,000.00 due to some minor damage but still with a 6 year warranty. It is a Ryobi with a 42 inch cut, 3 variable traction speeds & 3 cutting speeds. It is just amazing. No smelly fuel or oil changes, no belts or pulleys & quiet so no hearing protection required. It can mow up to 3 acres on a single charge.
The 2 cutters have 2 blades each at slightly different levels so the grass is cut really fine & with the mulch plate fitted the lawn looks lie a bowling green.
Absolutely. When I had a petrol mower (no sensible wireless electrics available and a large area to cut) the annual service used to cost as much as buying another mower (similar financial ownership profile to electric car ownership). No regrets going electric (free fuel from solar panels) and better for the planet. :)
The ryobi stuff is good.
