Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
- MG ZS EV
Today, our thoughts of a trip out was suddenly brought to an abrupt end, when we could not get the handbrake to release on our ZS EV !.
I jumped in and followed the standard start up procedure and all was fine.
Then I selected "reverse" and tapped the "GO" pedal, at this point the car wil slowly start to creep backwards, but not today !.
I pressed the "GO" pedal a little more and the O/S/R of the car started to lift up.
After numerous attempts to leave the car and return about 20mins latter, it refused to move either forward or backwards.
So, I reached out for our old friend the 10mm spanner, disconnected the 12 volt battery and then returned after about 45 minutes.
Reconnect and try again, same result car totally stuck !.
I rang the A.A. ( First time in over 45 years of driving ) and after just over one hour, he arrived at our home address.
He tried to connect his lap top to the car, but was having difficulty locating the ZS EV model.
A bit more investigation work and it appeared that the handbrake motor in the O/S/R wheel was making some strange noises.
At this point the car was reporting dash panel warning errors with the "Auto Hold" system and then the "EPB".
The A.A. guy then decided to remove the electronic handbrake motor to inspect it.
He handed me the motor and said he thought that the unit had "stripped the drive shaft" internally.
Also, he said he had seen the same problem on a few Volvo's.
Then he manually releasing the parking brake, by unwinding the tension from the pads by using a suitable sized spline bit and a ratchet.
Now, at last - we could move the car !.
The N/S/R parking brake appeared not to be affected and was working fine.
I did a small test drive and all was fine, but I had to apply the hand brake manually and it was only operating on the N/S/R of course.
He suggested that we deliver the car straight to the closest dealer ( about 8 miles away ) and this we did.
The A.A. guy was brilliant to be fair, it was almost 2 hours before he left for his next job.
He would not leave until I was totally happy that he had done enough, he even offered to organise a replacement car for me.
I did manage to speak to the service receptionist just before they closed at 12.00 mid day on Saturday.
They told me to try and get the car to them ASAP ready for looking at either Monday or Tuesday.
When we arrived, there where NO service staff available, so I left a message with one of the car sales team.
He followed us out to the car and spoke with the A.A. guy, who ran through the problem on the car.
I need to call the dealer first thing on Monday morning and speak to the service department.
Pure guess work on my part, but I figure the motor will be the same unit on the ICE versions and therefore hopefully getting a replacement part should not taken TOO long, fingers crossed.
The car has covered over 16,000 miles and is about 20 months old.
This is first thing that has failed or been a big problem.
I used the car the previous day and it gave me NO impression there was any type of problem in the making.
At least the problem happened on my own driveway, it could have been a huge problem at any other location !.
I will keep you posted on the car's progress.
I did a quick search on the forum, before posting to see if this issue had been reported by anybody else ?.
But no result's, so it would NOT to be a common problem then ?.
